Old 03-16-2015, 11:25 PM   #1
Gray overflow to black?
We have 1 gray tank and 1 blank tank, both 36 gallons. We typically will fill the gray tank well before the black tank. Having a practical means of shifting some gray drainage into the black tank would be useful, but I'd rather not do that manually with buckets, trekking it into the toilet.
In another thread I saw a reference to plumbing mods to allow shifting some gray water overflow to the black water tank. I used search and browsed lots of thread but can't find any mention of such a modification. Can someone point me to a description?
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 03-17-2015, 07:35 AM   #2
no mods yet i just take a 5 gal bucket and either dump the gray down my potty if boon docking or down the bath house if camping. i would be interested in maybe adding a mod if it did not take major changes
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 03-17-2015, 07:53 AM   #3
Water and ?? seeks its own level! Trying to balance both tanks is a (Messy) idea with very Little gain! Youroo!!
Old 03-17-2015, 08:03 AM   #4
I'm skeptical, too, but am willing to consider the option if someone else invented a way. There are geniuses among us.
- 2000 Coleman Mesa
Old 03-17-2015, 08:24 AM   #5
Dave_Monica's Avatar
I don't see anyway to cross-connect the two tanks without contamination of one to the other ie black into gray. The bucket method may be low tech but it's the best solution.
Dave
Old 03-17-2015, 10:30 AM   #6
When dumping full tanks I briefly hold both camera open but only after the black tank is fully drained and the gray tank is still full. I then close the gray valve promptly and allow the black tank to drain again. After that I close the black valve and don't allow communication between the two. Any further rinsing of the black tank is by way of a clear segment with attached hose.
- 2000 Coleman Mesa
Old 03-17-2015, 11:20 AM   #7
vinmaker's Avatar
The most practical way would be to simply install a connection hose from the grey to the black. As was pointed out, water will seek its own level. You therefore need to pump the grey water up and out of the tank and then deposit it into the black. This is really a simple Mod. Just need a bit of hose and a small pump.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-17-2015, 12:27 PM   #8
Really don't want to cross connect the gray and black. Keep two separate systems. GOD forbid somehow a cross connect and blocked black tank sewage will flow up into the shower, sinks etc.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 03-17-2015, 12:45 PM   #9
Fulltime family RVer
Warnings aside, I've read of other folks using a valve at the sewer connection and using it to equalize the tanks:
I've never done it, though.
Old 03-17-2015, 01:45 PM   #10
I do something like that by opening the gray valve after the black tank is empty but only if the gray tank is relatively full, to reduce the likelihood of backwash.
- 2000 Coleman Mesa
black
