Old 05-14-2015, 09:32 PM   #11
Left Coast
And something to support it.
Old 05-15-2015, 04:29 AM   #12
Oaklevel's Avatar
Originally Posted by steveo2626 View Post
Thanks everyone for the help. I think I just need to get one of these:
Then I'll just need to buy a new gray water valve/flange and some fittings/pipe to attache to the end of they gray water line. Not too bad I suppose.
Yes that should work
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-15-2015, 05:45 AM   #13
bikendan's Avatar
steveo, once you get this issue fixed, suggest you visit the Hybrid/Expandable section here, since the 18th is a hybrid TT.
There's even a Surveyor sub-forum there, where you can discuss things with other Surveyor owners.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-15-2015, 12:28 PM   #14
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
You really should incorporate them so you can flush the black out of the hose with grey water. Otherwise, you're going to be having a nasty problem down the line.
Grampa Jim is offline   Reply With Quote
Old 05-15-2015, 03:58 PM   #15
That Tee should work fine with a gray water valve and a black water valve. If you added a common valve after those two you can have added flexibility to transfer gray water to your black water tank. You'll find the gray water fill more rapidly than the black. With a common valve closed and more water in the gray tank than the black, you can open the gray valve then the black and gravity will transfer the gray water to the black. It is also a method for flushing the black tank after draining.
2011 Flagstaff V-Lite 30 WRLS
2007 F250 SD
chasbo70 is offline   Reply With Quote
Old 05-15-2015, 04:03 PM   #16
vinmaker's Avatar
X2 on the Tee valve set up. That is all you need to do. I agree the unit was most likely a seasonal RV and it was simply dumped into a proper drain.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-16-2015, 06:03 AM   #17
Missing parts
Maybe someone cut it to hook up to a permanent drain and kept the black water valve for periodic drainage. Definetly been modified by removing the drain valve for the gray for some reason.
magpi26 is offline   Reply With Quote
drain, water
