Old 05-18-2015, 09:11 PM   #11
Evereddie's Avatar
Originally Posted by Filthy Beast View Post
Personally I don't think the water heater should be in the fresh water calculations. When the fresh water tank is empty there is nothing to push the 6 or 10 gallons out of the water heater.
Exactly. I was just going to say that.
Evereddie is online now   Reply With Quote
Old 05-18-2015, 09:15 PM   #12
Evereddie's Avatar
Originally Posted by vinmaker View Post
But would the water pump move it? That is the question I think. Does the water flow from Fresh tank to water heater to pump to faucet? If so then the two tanks in total before the water pump could be viewed as a single capacity. Fuzzy specs if you ask me, but I can see that being done.
Vin.
It goes from fresh water tank to pump and then water heater and then faucets. There is no way to use the water in the heater once the fresh water tanks runs dry.
Old 05-19-2015, 01:00 AM   #13
Wouldn't be 1st time customer gets lied to
cj06 is offline   Reply With Quote
Old 05-19-2015, 08:32 AM   #14
JAL
Assuming you have outside kitchen I see in floorplan, where does your outside sink drain to? Is there a separate, smaller gray tank? (I've never had an Outside Kitchen so I don't don't know how they are plumbed.) Thanks
JAL is offline   Reply With Quote
Old 05-20-2015, 08:46 PM   #15
Happy Camper
I talked with the F.R. warranty dept. today. Jessica listened to my complaint, which took a while to explain (???) and then advised she had to have the actual part numbers off the tank to verify. Amanda at Camping World, said she will get those numbers and contact them ASAP. The "tree has been shook" and they all know I have their direct phone numbers and will keep calling until this is resolved. I am sure it will be a few days but I will post again.
Johntgif is offline   Reply With Quote
Old 05-20-2015, 08:51 PM   #16
Happy Camper
JAL,
To answer your question about the outside kitchen sink, it does dump into the main gray tank but very little water is used there. Mostly while washing hands to cook. Don't necessarily need clean hands to get a cold beer out of that refrig. Ha!
tank, water, water tank
