Old 04-25-2015, 06:58 PM   #1
stansoper's Avatar
Gray Water Tanks Wildwood 29fkbs Travel Trailer
New 2015 Wildwood 29fkbs Travel Trailer 64 Gal Gray Water Capacity. It has two gray water tanks, one for the kitchen and other for the bath. Does anyone know what the capacity of each tank is? When draining the tanks, I know to drain the black water tank first followed by the gray water tank. It looks like the kitchen has a separate valve and the bath and kitchen connect with another valve near the black water valve. When draining the gray water tank, do you open the kitchen and then open the main gray water valve to drain both tanks tanks simultaneously or is there a better way? My previous travel trailer only had one gray water tank/valve.
ID:	75219   Click image for larger version
stansoper is offline   Reply With Quote
tank, trailer, travel, travel trailer, water, water tank, wildwood
