I would disconnect the top two sensors and see which lights are lit. Make sure there is enough water in the tank to cover the bottom two sensors. Then attach one of the wires you removed to the second sensor and check the lights. You should be able to confirm which wires control which lights. You should be able to take the wires off of the sensors by removing a nut on the sensor. Unless the wires are short, you can move the wires without cutting them.
It seems that the way these trailers are put together, anything is possible! Yesterday I put two gallons of water (with a cup of Borax dissolved in it) into my empty black tank and it went from empty to 1/3 full.
When it dries up outside, I'll check the wire colors on my tanks.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
