Old 10-26-2014, 02:46 PM   #1
B and B's Avatar
Grey tank issues leaking or cracked?
We had a full grey water tank for the bath. Sitting outside the vent was dripping underneath the trailer. Dumped the tank all was well. So come the next question is the tank cracked or the pipe connection broken. Anyone ever had this issue?
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-26-2014, 03:28 PM   #2
mark0224's Avatar
You said Bath? was it cold out that day? could it have been condensation on the outside of the tank because of the warm water inside the tank ?
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-26-2014, 05:05 PM   #3
B and B's Avatar
It is cold but there was too much water for condensation. We are still camping tonight. I will let you know what happens later.
Old 10-26-2014, 08:13 PM   #4
I had that issue on a Berkshire. It started at Goshen thank goodness and FR replaced the gray tank. The reason it cracked was as it became full the top of the tank would expand and as that moved with expansion the PVC pipe the drained into the top of the tank was plumbed without any flex. So the tank would rise up on the top but the connection was ridged and caused the tank to crack at the inlet. They tried to fix it several times but every time it would just be worse. On new units the use a flex hose in the line to allow for movement.
Now this may not be what happened to yours but it's worth checking out.
Old 10-28-2014, 07:10 PM   #5
B and B's Avatar
Funny thing is we had a wicked smell last night in Goshen that I thought was the air admittance valve. Tomorrow morning going to pull things apart and have a look.
Brian
Old 10-28-2014, 08:37 PM   #6
RKR
RKR's Avatar
On my shakedown trip last year my galley gray tank leaked. The connection at the tank wasn't glued at the factory.
The dealer pulled the underbelly material, washed it and glued the connection. No problems since.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 10-29-2014, 06:36 PM   #7
B and B's Avatar
Today I found that the connection to the tank is not glued. The pipe moves around. Now two thoughts. If UT floats the connection won't be broken I'd the tank overfill. It does leak a little once and while I can just deal with that. It is a picture of a inspection camera. The pipe does move up and down on what appears to be a through sleeve attached to the tank. I can get at it by pulling the converter I I choose to seal it up.
This was not the cause of the smell I had in Goshen. That was the air admittance valve.
leak, tank
