Old 01-03-2020, 12:22 AM   #1
rlryder's Avatar
Grey Tank Overflow
First time out in our 2019 2511S and we evidently filled the grey water tank completely full. When I got to the dump station I noticed water leaking under neath the trailer from the grey tank somewhere. It continued leaking until I finished drawing the grey water tank. It was leaking above the under belly. I recreated the problem in my driveway when I got home. It didn’t start leaking until the tank was completely full. I was wondering if there might be an overflow relief valve in the plumbing system.
Not sure if you can see the leak in attached photo. Water was leaking where the discharge pipe protrudes thru the under belly.
rlryder is offline   Reply With Quote
Old 01-03-2020, 02:40 AM   #2
Coach
I've never known grey tanks to have an overflow. Full tanks back up into the drains. You may need to investigate for a leaking drain or a crack in the tank.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is online now   Reply With Quote
Old 01-03-2020, 05:52 AM   #3
Chris Pastuzyn's Avatar
Which grey tank, Mine has 2 one for the galley and the other for the bathroom.
Chris Pastuzyn is offline   Reply With Quote
Old 01-03-2020, 07:12 AM   #4
bedubya's Avatar
Is there a drain vent attached to your sink drain?
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
Old 01-03-2020, 08:03 AM   #5
It could be several things.
As mentioned, a cracked tank or leaking connection or even where the vent stack goes into the top of the tank.
You are going to need to pull the underbelly and have a look. A 2019, if you have warranty, have someone look at it for you.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 01-03-2020, 08:07 AM   #6
cavie's Avatar
There is no OVERFLOW on a gray tank. Shower pans are a know leak problem.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-03-2020, 08:11 AM   #7
Yes. Mine overflowed when near full. The bulging belly was the clue. The dealer discovered cracked fittings at the tank.
My most favorite people are Navy Corpsmen and Marine medivac helicopter pilots and crew - MEJ 1968
mjacxx is offline   Reply With Quote
Old 01-03-2020, 10:50 PM   #8
The tank will have a vent. Depending on the location of that vent it can also act as an overflow.
My galley grey tank has a vent that will act as an overflow. There will be about and inch or two of water in the sinks before it would go out the vent. The vent goes outside on the rear of the trailer.
My grey tank for the bathroom vents through the ceilingg I think.
quicky06 is offline   Reply With Quote
tank
