Old 11-21-2014, 03:20 PM   #1
blythepyrate's Avatar
Grey water Clog
Help, a friend came over and washed a bunch of steak grease down my kitchen drain now it appears that I have a clog. Grey water is backing up into the bathroom sink. Three pots of boiling water down the kitchen sink has helped kitchen drain but grey water is still backing up into the bathroom sink. This is a 2009 Sunseeker MH.
Can I use a drain chemical? I bought some. I'm not sure I have many choices at this juncture. We are camping pretty far from any major city, 10 miles to a very small town.
I am hooked up to sewer and have emptied both tanks.
Pyrate
Fuzzy Bear (Newf) & Emmett (ginger cat)
2009 Sunseeker 2900 & Jeep Cherokee Sport
blythepyrate is offline   Reply With Quote
Old 11-21-2014, 03:29 PM   #2
heavynlori's Avatar
Is there a separate pull for your shower gray ???
heavynlori is offline   Reply With Quote
Old 11-21-2014, 03:30 PM   #3
I'm not sure what a pull is but it must be on a separate system because I took a shower just fine.
Pyrate
Old 11-21-2014, 03:31 PM   #4
heavynlori's Avatar
Pull - handle to pull to empty the gray water
Sometimes there are two grays on the camper
Old 11-21-2014, 03:32 PM   #5
heavynlori's Avatar
All usually comes out one outlet - just need to pull the right handles !!!
Old 11-21-2014, 03:33 PM   #6
Just one grey pull as far as I know. I was only shown one, I've only have a camper since May. I think the second one is unlikely.
Pyrate
Old 11-21-2014, 03:56 PM   #7
This is not a full grey tank issue. I have emptied the grey tank many times successfully. There's a clear cause and effect of grease going into the drain creating a problem.
Pyrate
Old 11-21-2014, 04:14 PM   #8
KenHwy61's Avatar
If your thinking a common type of drain cleaner I don't see why it would hurt your drain pipes any. They are the same plastic found in many houses.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-22-2014, 12:35 AM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
My 5r has two greys and two black "pulls". It's like a manifold system when connected. If your worried about the grease thing then dishwater soap with warm water should cut the grease.
donanddona is offline   Reply With Quote
grey water, water
