Old 06-14-2014, 04:26 PM   #1
Bobo
Grey water pipe replace
I have a 2012 Windjammer 3008W. I have freeze damage to my rear grey water drain. I need to replace some parts.
The 1 1/2" valve is still good, but the piece that bolts on to the valve is cracked and the elbow is also.
Can anyone recommend replacement parts using a local hardware store or a discount part dealer?
What is the grade of plastic being used ? Obviously not schedule 40.
I am trying to do this myself. At $120.00 an hour labor, it has already cost me plenty just to get the camper usable. ( See Camco Antifreeze Problem).
I went to CW but I did not see the part that goes from valve to pipe or any pipe available. They were too busy to help me.
Thanks.
Bobo
2011 Ford F-150 Crew cab FX4 Ecoboost
2006 Sunline T-2499
2001 Coleman Utah
Bobo 3008 is offline   Reply With Quote
Old 06-14-2014, 04:54 PM   #2
Grn_Mtns's Avatar
cut out the offending parts & Find a. Hardware store. Camper is ABS but is interchangeable with sched 40PVC
Look over the "fernco fittings " and get a bottle of glue . Have fun till it stops leaking!
Sent from my HTC One_M8 using Forest River Forums mobile app
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 06-15-2014, 03:14 PM   #3
Bobo
Grn Mtns,
Thank you.
Got what I needed at HD. Went back to CW and found the valve flange I needed. Found it in the fresh water aisle. Stupid me only looked in the sewage aisle.
Bobo
2006 Sunline T-2499
2001 Coleman Utah
Old 06-15-2014, 03:24 PM   #4
Grn_Mtns's Avatar
Awesome ! How is the windjammer 3008 treating you? Our 3025 has been great so far. We may be part of the awning motor recall but otherwise no problems.
Best,
Jon
Old 06-15-2014, 05:39 PM   #5
Bobo
To be honest, I found that our Sunline we traded in was better quality. Besides the freeze damage from this past winter, I have replaced the spotlights in the bedroom because when you replace the bulb, the socket pushes in causing a short. The small round lights in the bath, I had to pull the whole unit out just to change a bulb. 2 rivets went on our front step. Under warranty, I had the roof replaced on the bed slide due to faulty glue on the rubber membrane. I had replaced a 110v outlet that came broken. Another one just cracked.
Just waiting for what's next. We love the layout. It solved the room size problem we had with the Sunline. Shame they went out of business. I would of bought another one in a heartbeat.
Enjoy your unit. Ours is our Happy Place.
Bobo
2006 Sunline T-2499
2001 Coleman Utah
Old 06-15-2014, 06:22 PM   #6
Grn_Mtns's Avatar
Sounds above average so far. Good luck
Best,
Grn_Mtns
grey water, water
