Old 04-02-2015, 03:17 PM   #1
H2O heater
I tried several times to turn water heater on gas, grey wolf 26rl, and can't get it to light. Works on electric. Model sw6 de. Have no idea what push to reset buttons do and I've read operational book.
71ump is offline   Reply With Quote
Old 04-02-2015, 03:28 PM   #2
Ford Idaho's Avatar
Have you purged the air out of the lines?
Does the stove or oven work?
Old 04-02-2015, 03:32 PM   #3
There is also a 12v hi temp limit switch under the left rubber plug that might be tripped OR burned out.
Old 04-02-2015, 03:38 PM   #4
Herk7769's Avatar
When the water heater is trying to run on gas:
From outside with the cover down,
1) Can you hear the "snapping" of the ignitor
2) Can you smell gas?
HAM CALLSIGN - KC3FFW
Old 04-02-2015, 03:47 PM   #5
caper's Avatar
Is the water already hot from the electric side? If water is hot heater will not start.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-02-2015, 03:48 PM   #6
. Thanks. The stove n oven work. Not real sure how to purge air out system. The igniter does not pop nor do I smell gas.
Old 04-02-2015, 03:49 PM   #7
No it doesn't snap nor do I smell gas.
Old 04-02-2015, 03:50 PM   #8
Ford Idaho's Avatar
Ok, your line has been purged so I suggest you try the other tips posted above.
Old 04-02-2015, 03:51 PM   #9
Looking at it I do not see this switch. Nothing looks or smells burned.
Old 04-02-2015, 03:53 PM   #10
wmtire's Avatar
X2 as I was thinking this may be the case as the thermostat wouldn't sense the need to heat.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
heater
