Old 09-22-2010, 09:14 PM   #1
h2o heater
this may be stupid ,but is there an adjustable t-stat for the water heater . I can't seem to find one on mine.
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
Old 09-22-2010, 09:16 PM   #2
Not a stupid question at all. The answer though, is no. The DSI water heaters do not have a thermostat on them, at least not mine. They are preset by somebody at the factory that decides how hot you need to have your water.
Hokiehall is offline   Reply With Quote
Old 09-22-2010, 09:18 PM   #3
that sucks. maybe I have a problem then. ours only gets luke warm at best. I have even tried electric with gas.
2011 Ram Laramie
Old 09-22-2010, 10:59 PM   #4
NWJeeper's Avatar
Most of them use a thermal switch that is in contact with the side of the tank. They are small, round and have two wire leads connected to them. They are sometimes refered to as TCO (Thermal Cut Off) switches. The switches are used on many RV appliances and are available in many different temperatures. Water heaters are set to 140 degrees typically. On some heaters there may be two of them the 2nd one is a safety and is set at 160 or 180 degrees. You would need a parts breakdown of your water heater to see where your switches would be located. You can buy the switches and just replace with primary with the setting you want. In many cases it is more work than it is worth in my opinion.
Ed & Wendy
www.nwjeepn.com
Old 09-22-2010, 11:14 PM   #5
Check your winterization bypass valves and make sure they are in the proper position. If the one from hot to cold is left open, (behind the water heater normally), you won't get very much hot water. Search other post on here for diagrams and directions.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-23-2010, 06:47 AM   #6
KyDan's Avatar
What he said!!
Also here is a thought. If you are VERY CAREFUL you
could try pulling the handle on the pop off valve on
the water heater. Wear rubber gloves and stand back but
what I'm suggesting is to get some water out of there and
see if it really is luke warm. If it's uncomfortably hot as
I suspect it will be, then you have a bypass valve set
1/2 way or all the way in the wrong position.
Let it cycle on until it's "hot" and then shut off gas and
electric before you try this!!
You don't say what make or model of HW heater you have
but I believe they now come with 120 degree preset
thermostats. You can order one that's 10 or 20 degrees
hotter from the factory or some well stocked parts
places.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-23-2010, 07:03 AM   #7
milzat's Avatar
EXCESSIVE OR INSUFFICIENT WATER TEMPERATURES
Problem: Bypass kit valves not set properly
Solution: Place valves in proper position
Problem: Thermostat not seated against tank
Solution: Re-seat thermostat
Problem: Defective thermostat
Solution: Replace thermostat
Parts Page
milzat is offline   Reply With Quote
Old 09-23-2010, 10:37 AM   #8
thank you everyone , I will go through it all on the weekend. at least now I have starting points.
2011 Ram Laramie
Old 09-23-2010, 03:56 PM   #9
Villa Estate 392FLFB
The_Stuff's Avatar
i thought my heater was junk to until i took the panel off and saw the bypass valve was open aswell!!
One state/province at a time!
The_Stuff is offline   Reply With Quote
