Old 04-28-2019, 08:23 AM   #1
WNK2304's Avatar
Hand Spray Or Not?
Ok, ready to upgrade the Dometic 300 to the 320 and wondering if I should get with or without the hand spray. Current 300 doesn't have one and think another place for a water leak is a no-no.
Also, if hand spray is needed would it be better to just plumb one in as opposed to having it part of the toilet valve?
Would like to hear your opinions and/or ideas.
'18 Rockwood Mini Lite 2304
'13 GMC Sierra 1500 Ext Cab 4x4
WNK2304 is offline   Reply With Quote
Old 04-28-2019, 08:39 AM   #2
NMWildcat's Avatar
Have never needed a hand spray for a toilet. Can't say I would use it if available. Some folks go to great lengths to have one.
Another potential leak source shouldn't be a decision factor. What's one more
Let us know what you decide and why.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 04-28-2019, 08:49 AM   #3
Flybob's Avatar
IIRC the 320 is slightly larger than the 300. Make sure you have the clearance you need especially behind it. The critical distance is usually the center of the hole to the back of the toilet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-28-2019, 09:24 AM   #4
Kanadian Kamper
kenandterry's Avatar
What Flybob said.
Measure several times, the distance from the center if the hole to the back wall.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 04-28-2019, 09:27 AM   #5
If I replace I will go with the hand spray. Chasing stuck Toilet paper is a PITA.
Old 04-28-2019, 10:38 AM   #6
WNK2304's Avatar
Originally Posted by kenandterry View Post
What Flybob said.
Very good advice, all planned out, will go as smooth as a babies, uh,
should go smooth....
Old 04-28-2019, 01:32 PM   #7
When I looked into adding a hand sprayer to ours it wasn't going to be easy. So if you want a hand sprayer get the one with it.
shadows4 is offline   Reply With Quote
Old 04-28-2019, 02:32 PM   #8
Erinn
We 100% agree - never had a sprayer b4, but now that we do, we love it!!
SunseekerFunseekers is offline   Reply With Quote
Old 04-28-2019, 03:02 PM   #9
I think the 320 has an elongated bowl which appeals to those of us gifted with a more generous girth. Also it will accept a STD replacement toilet seat.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 04-28-2019, 03:09 PM   #10
Never had a hand sprayer and never took a dump and said... "Gee, I wish I had a hand sprayer."
Use plenty of water and I don't see a need. But it is YOUR choice. Go for it if you want one.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 04-28-2019, 05:03 PM   #11
Have lived in the RV for 2 years with a hand spray and never use it. No problem with leaks.
jdkbrooks is offline   Reply With Quote
Old 04-28-2019, 05:24 PM   #12
frank4711's Avatar
Came on new 310 ... have to wait and see ... works good plenty of pressure
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 04-28-2019, 05:50 PM   #13
bedubya's Avatar
My handheld shower reaches, but have never seen the need to use it.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
bedubya is offline   Reply With Quote
Old 04-28-2019, 07:10 PM   #14
I had to change my water line for my 320 . Be ready for that . A much better toilet for comfort . Forget the hand held spray . Never used it on our old toilet , just make sure to measure so the 320 will fit..
fred+sherry is offline   Reply With Quote
Old 04-29-2019, 07:33 AM   #15
Weekender
burks's Avatar
Making life easeir
Get the toilet that has the hand sprayer built in that way it has no pressure on it unless you flush the toilet. The sprayer is one of those items that makes life a littler easier! The people that don't use sprayers must have another way to clean the toilet. To me the sprayer is the easy way to clean the bowl when needed.
burks is offline   Reply With Quote
Old 04-29-2019, 07:38 AM   #16
NMWildcat's Avatar
We clean the toilet the same we do at the stick and brick house. No magic. I think a sprayer would be fine if it came OEM, but I wouldn't add one.
Old 04-29-2019, 08:03 AM   #17
Herk7769's Avatar
With!
Makes cleanup a breeze and will not waste water when dry camping. A short spray down will get the bowl ready for the next person very quickly.
I have installed a spray wand in every camper I have owned. Once you have one, you will wonder how you ever got along without one.
Name:	Camper Bidet 035.jpg
ID:	203128   Click image for larger version
Name:	Camper Bidet 038.jpg
ID:	203129   Click image for larger version
Name:	Wash Down Sprayer.jpg
ID:	203130   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-29-2019, 08:06 AM   #18
Herk7769's Avatar
I found the pressure drop from trying to use it while the flush valve is open, too excessive. I plumbed all mine to use direct pressure.
Plus I can use the wand to add water to the bowl if solids are anticipated.
Old 04-29-2019, 11:29 AM   #19
Put more water in prior to flush
pdqparalegal1 is offline   Reply With Quote
Old 04-29-2019, 01:12 PM   #20
n0ms's Avatar
Sprayer, AKA Poop Shooter.
n0ms is offline   Reply With Quote
