Old 09-21-2014, 07:47 PM   #11
Assistant TP Supervisor
The Black flush vacuum breaker is a loop up behind the shower in my unit.The water comes back out when I disconnect. Thinking air would adequete or the Youroo method.
B and B is online now   Reply With Quote
Old 09-26-2014, 06:55 AM   #12
EastlakeRoo's Avatar
I typically go overboard when winterizing by blowing out all the lines with air and then running the bypass water pump converter which draws the antifreeze from the bottles thru the entire water system. I just turn on/off everything in the trailer including outside shower and sink.
To add to the process, I recently purchased a hand pump to do the external black tank inlet plus main water inlet. Attaching a photo of pump. Think Amazon has them real cheap now.
I like the idea of using the external shower hose to do same thing but took the easy route and just bought another tool.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
