03-28-2016, 06:46 PM
Have to replace ENTIRE water filter housing
I've never had a unit with a water filter, so draining it for winter never entered my mind. My bad. Lesson learned.
Moving on...
The entire water filter housing busted....the canister as well as the white cap that the PEX runs into and out of. I ordered the part, and it is due to arrive tomorrow.
It seems this should be a relatively easy replacement, but I just don't have that kind of luck.
Have you ever replaced one? Or maybe removed yours to install something else? What do I have to look forward to? Any helpful hints or suggestions?
Here's a pic of the entire housing....like I said, the PEX runs into and out of the white cap.
Christian
Reno, NV
2015 Georgetown 270
Days Camped 2015: 40
Days Camped 2016: 03
03-28-2016, 06:50 PM
Most just remove and bypass. Use external filter..
03-28-2016, 06:53 PM
Pull it out. At least you were lucky and it broke without water pressure in it. Just use an outside filter and save yourself the trouble of it breaking again later.
2019.5 Rockwood 2509S
03-28-2016, 06:57 PM
I've been reading that. So is it easy enough to remove the white cap?
And then what....just connect the two ends with a piece of PEX?
Christian
Reno, NV
2015 Georgetown 270
03-28-2016, 06:59 PM
!/2 threaded PVC coupler like this.
A roll of thread tape.
Hook the two ends of the water line together after you remove the broken head.
Use the new one outside.
03-28-2016, 07:05 PM
Thanks!
Christian
Reno, NV
2015 Georgetown 270
03-28-2016, 07:18 PM
Or cut off both fittings and use a 1/2 sharkbite coupling and just push it on
03-28-2016, 07:22 PM
Got it! Thank you.
Christian
Reno, NV
2015 Georgetown 270
03-28-2016, 08:41 PM
Here's a thought. If you are going to replace it anyway why not install one similar as shown instead of one like original. The one shown here does not have the issues associated with the one like yours and the filters are standard 10 inch and easy to get from HD/Lowes/Walmart etc. for around $8 for 2, not the $30 each for the KW1 you will need. Just a thought.
03-28-2016, 09:54 PM
Another great idea! Thanks!
Once I remove the white cap and get a feel for what I'm dealing with, I will make a decision about which way to go. Using an external filter does sound appealing, so I don't have to worry about it when winterizing. We'll see...
Good stuff to consider... I certainly appreciate all of the help.
Christian
Reno, NV
2015 Georgetown 270
03-29-2016, 09:35 AM
The issue with any internal filter is that if it breaks or cracks for any reason, you'll end up with water all over the inside of your trailer. By bypassing it completely and putting it outside, you no longer have to worry about cleaning up a mess if it breaks.
It also makes it nearly impossible to forget to remove and drain during winterization.
03-29-2016, 11:41 AM
I had a blow out with the same filter assembly. I removed it, cut the Pex fittings off, and spliced in a short piece of pipe using shark bite fittings. I bought a dual canister exterior system. Check out RV Water Filter Store on line for some good information. Good luck.
FroggyRon (Ron)
2014 Forest River Georgetown XL 377
2014 Jeep Cherokee Latitude 4X4 toad
03-29-2016, 12:25 PM
Canadian Member
The FR1 housing seems to have a reputation for loosening on its own, either that or the design is not well understood and people don't put the canister on properly.
My previous Roo and my current TT have the WaterPur CCI-10-CLW housing and that one seems to be fine.
The RV Water Filter Store website has good info on the types of filters you can install. What you use depends on how much you trust the water source. You usually get what you pay for.
03-29-2016, 03:13 PM
I cut it out and put a sharkbite connector from Home Depot in between. The expensive part is the Pex Crimping Tool. But I have added to my list of must have tools in the trailer and I have a couple lengths of red and blue pex tubing plus clamps in my storage area. Came in handy when pex connectors under bathroom sink leaked.
I use the external filter for filling up fresh water and connecting to city water. Very inexpensive at Walmart.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
03-29-2016, 05:28 PM
jkoenig24
My Dynamax DX3 had a PROPRIETARY whole house filter. Standard, readily available filter cartridges would NOT fit. I had my local RV guy replace the whole mess with an industry standard set up. Now, I can buy filters anywhere and, at prices that are MUCH lower than what I'd have to pay Dynamax. That encourages me to change the filter more often.
03-29-2016, 05:39 PM
I replaced my OEM filter in the convenience center with one from Lowes as like stated, it uses standard over the counter filters. I've most always had the filter mounted near the convenience center on my previous fivers with no issues of failure I read about here on the FR website. I think it's pretty hard to forget to winterize it when it stares you right in the face every time you open the storage door.
04-01-2016, 06:52 PM
I did this exact same repair/change today. ...taking it out tomorrow to hook it up and check for leaks.
*fingers crossed*
Thanks to all who contributed to the discussion. I appreciate the help.
Christian
Reno, NV
2015 Georgetown 270
04-01-2016, 07:07 PM
HD/Lowes,whole house filters mounted Outside Only way to go! You select the Filtration Element of Your choice to put inside! Mounted for Easy removal on the Frame rails! Youroo!!
04-07-2016, 07:31 AM
Is there any special mount you had to get to mount it under the rv?
NavigatorC130A
2011 F250 Super Duty 6.2L 16-Valve EFI V8
2013 Rockwood 8281SS Revolution Pin
04-07-2016, 07:39 AM
I'm thinking about removing mine and filtering prior to going in the tank with hose mounted filter.
Retired Navy
2016 Flagstaff 26 FKWS
