Old 09-29-2011, 10:22 AM   #11
Villa Estate 392FLFB
The_Stuff's Avatar
this for the long sections
this for any turns and sealing up joints of the above stuff
Really why throw the heat out there? it just wastes power! lol
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-29-2011, 10:58 AM   #12
CLASS "A" Senior Member
cfsoistman's Avatar
PIRIT Heated Hose : The Only Cold Weather Heated Hose
Saw this at the Hershey RV Show. Real nice set-up, a bit pricey but it's manufactured with the heat coils within the hose jacket itself.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-03-2011, 06:27 AM   #13
MissouriCamper's Avatar
I'm afraid some misunderstood my question, my hose has heat tape directly on the hose with pipe insulation on top of that. Never had a freeze up. At a campground a buddy of mine insisted that aluminum foil tape needed to be wrapped around the hose first then the heat tape and insulation or I was in for certain failure. As I said I've never had a failure despite a lot of winter rv'ing. Just thought I would through it out for opinions.
Mike & Shirley
Millwright (Retired)/Homemaker
2009 F250 SD Super Cab
6.4L Diesel 3:55
2018 Flagstaff 25FKS
MissouriCamper is offline   Reply With Quote
Old 10-03-2011, 07:31 AM   #14
Herk7769's Avatar
In my opinion you are fine and your friend has been sniffing the glue that hold his foil tape on.
HAM CALLSIGN - KC3FFW
Old 10-03-2011, 09:43 AM   #15
i would not put foil between the hose and the heat tape - i think that would reflect the heat away from the water you're trying to keep from freezing. OVER the tape, fine. UNDER the tape? no.
rawlus is offline   Reply With Quote
