YES, you definitely must have a water supply going to the WH, either the fresh tank via your onboard 12v pump, OR hooked up to a garden hose pressurizing the whole system. Like mtnguy said, be sure you have water at the hot faucet BEFORE firing up the WH, either on gas or electric. That tells you that your tank is full, so you don't burn up the element. Randy
