Old 08-20-2013, 07:02 PM   #11
Broadway Joe's Avatar
Pictures and video at 11 PM
Broadway Joe is offline   Reply With Quote
Old 08-20-2013, 07:34 PM   #12
soccerloco's Avatar
I think I have explained my problem clearly. It is perplexing just asking for help no video
soccerloco is offline   Reply With Quote
Old 08-20-2013, 07:42 PM   #13
Was posted in jest, not trying to tweak anyone here. I understand your frustration and I was not helping. I can't offer anything constructive to the problem.
Old 08-20-2013, 07:51 PM   #14
when you have it "empty" can you open the flush valve and look into the tank to see if its empty?
Acableguy06 is offline   Reply With Quote
Old 08-20-2013, 07:56 PM   #15
Leathergypsy's Avatar
Whatever the problem, It cant be that tough to figure out. I may be wrong but we're only talking about a tube (toilet) connected to a tank connected to a tube (outlet valve) All plastic....Obviously its blocked somewhere. Try a snake. If not, take it back to the dealer.
John N.
Madison Heights, Mi.
2009 Salem LE 27RBEC
2013 F250 Lariat 6.2L
Leathergypsy is offline   Reply With Quote
Old 08-20-2013, 08:15 PM   #16
VinceU's Avatar
Saw another post where a guy had the same problem. The toilet exit didn't lead to the black tank instead in entered a complex set of piping beginning with a 45 deg. ell. from they it meandered into the tank. Problem was not enough flush water. Paper etc entered the pipeline but would not flow. Eventually the bowl will fill up and drain very slowly. Maybe snake for some distance and use more water with each use.
Old 08-20-2013, 08:27 PM   #17
My toilet is directly over the black tank. When flushed you can look directly into the black tank. Have you gotten underneath and followed the piping to the black tank?
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 08-20-2013, 09:43 PM   #18
soccerloco's Avatar
Ran snake from the toilet down and also from the dump tank valve up. No success
Old 08-20-2013, 09:52 PM   #19
How far did the snake go each time?
Old 08-20-2013, 09:59 PM   #20
soccerloco's Avatar
Snake went several feet
