Old 08-20-2013, 10:10 PM   #21
Wilky's Avatar
Had same thing happen to me. Thought tank was full since I looked down the toilet and water looked like it was right there. Dumped tank and it still looked full. Since I was camping did not have anything like a snake but looked around and found a piece of 2x2. Pushed it down the toilet and that cleared the blockage. The pipe into the tank is Large so a snake could pass through and maybe not clear it but don't understand how you could pump out through toilet and not remove blockage. Sorry not much help.
Wilky is offline   Reply With Quote
Old 08-20-2013, 10:25 PM   #22
soccerloco's Avatar
Appreciate help. Pumper stick a pipe about 2 1/2 inches in diameter and apparently didn't unblock the problem. I am home now and will try anything
soccerloco is offline   Reply With Quote
Old 08-20-2013, 10:40 PM   #23
soccerloco's Avatar
Will continue to try.
Old 08-20-2013, 11:01 PM   #24
NELA
Weezer's Avatar
Are you saying it's filling up with "waste", or is it just water?
If it's water I'm thinking the water isn't stopping when you take your foot off the pedal. I.E. does it fill up by itself?
Disclaimer; I know next to nothing about this stuff, but you seem at wit's end so I'm just throwing thoughts out there.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-20-2013, 11:03 PM   #25
soccerloco's Avatar
It's not filling up black tank. Seems like the toilet itself gets full but not the tank
Old 08-20-2013, 11:16 PM   #26
MotocrossCamper's Avatar
Maybe pictures would help if there is no waste in the toilet and you can use just water to show the problem.
I agree that if the toilet used to work fine and just started doing this that it can't be a hard problem to solve.
MotocrossCamper is offline   Reply With Quote
Old 08-20-2013, 11:19 PM   #27
soccerloco's Avatar
When you open flush toilet is full to that point. It appears that toilet is not draining into black tank
Old 08-20-2013, 11:22 PM   #28
dannyabear's Avatar
I had same problem on old 5th wheeler.
Take a flashlight and look into toilet while pushing flush pedal. Ill bet tp is clogged in the transition from toilet to pipe. Asnake will go thru but it just re clogs. Or take garden hose and wash out toilet from inside.
dannyabear is offline   Reply With Quote
Old 08-20-2013, 11:23 PM   #29
soccerloco's Avatar
Thanks will try
Old 08-21-2013, 12:56 AM   #30
SYE
SYE's Avatar
Make sure that birds did not build a nest or squirrels packed the plumb vent on the roof!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 16 Nights Camped 2018 49 nights reserved
SYE is offline   Reply With Quote
