Old 10-25-2010, 06:34 PM   #11
Herk7769's Avatar
Originally Posted by Nursx2 View Post
About the relief valve. It says in the owners manual that it is supposed to leak a little ...but how much is a little. I find it leaks so much that the compartment under the heater accumulates water. Should I replace it?
They are not very expensive and easy to change. Use Teflon Tape or Teflon Pipe Sealant and make sure it is the correct pressure for your water heater.
I don't care what the manual says, they should not leak. If they did my basement would be underwater.
That is not to say they can't "pop off" and relieve pressure with a little water, AS LONG AS THEY RESEAT (seal). They are doing their job when that happens.
If it leaks all the time replace it.
HAM CALLSIGN - KC3FFW
Old 10-25-2010, 08:29 PM   #12
The relief valve should be tested as part as a PM program, this is a safety devise, if it fails then it should be replaced if it is old, but remember replace it with the same ratings (temperature & PSI) as the original. Corrossion can occur on the spring on the relief valve and weaken and then the valve will fail. This depends on the water condition as It does on the anode rod as to how fast it will corrode and how long the water stays in the tank.
As stated above as far as debris if it gets into the relief valve and it doesn't seal then should be a good indicator that the water tank needs to be cleaned out better and then test it....Flush, Flush, Flush.
Old 10-25-2010, 08:37 PM   #13
2003 Sunseeker 3100SS
Nursx2's Avatar
Thanks herk! I agree with what you have written. Thanks....I will be ordering a new one for the spring thaw - can't wait....is it April yet!?
Nursx2 is offline   Reply With Quote
Old 10-25-2010, 11:44 PM   #14
When I winterized my TT, I drained the water heater 1st, them used a long plastic nozzle (Camco I think) that I purchased @ CW to flush the crud out. The w/ a compressed air blow off nozzle that has 3/16" steel tubing soldered to it, I blew out as much water as I could. I then reinstalled the anode.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 10-27-2010, 07:46 PM   #15
Lightbulb
Here's the item I was posting about.
Amazon.com: Camco 11691 RV Water Heater Tank Rinser: Automotive: Reviews, Prices & more
Old 10-27-2010, 08:02 PM   #16
and do yourself a favor...if you use air to blow out your lines...don't bypass your water heater with the air pressure on... loooong story short...anode rods become dangerous projectiles with 50lbs pressure behind them. I use a wet dry shop vac also with a small hose that will fit in the anode rod hole to suck all the water out... wet and dry vac works great for the p-traps in the sinks ... then i dump in some antifreeze to replace the water. I do this as I don't want diluted antifreeze.
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 10-27-2010, 08:11 PM   #17
How do you you remove the anoid? What does the do? On my pop up there was a white plastic cap that I removed to drain the tank.
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 10-27-2010, 09:16 PM   #18
The Old Man
Willis's Avatar
Originally Posted by revrnd View Post
I have something almost exactly like that for adding water to my potable water tank...never thought of using it to flush the wh tank! It think it would work as long as the tank isn't hot!
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 10-27-2010, 09:27 PM   #19
The Old Man
Willis's Avatar
The anode is used on Suburban-brand water heaters. The anode is attached to the "stopper" so that it serves as the plug too. If I remember right, the anode plug on the Suburban is an odd 1-1/16" size. I had to go to the auto parts store and buy a socket to fit.
The purpose of the anode is to slow down corrosion of the wh tank. It's just like your home wh which also has an anode, which most people don't know about either and never change. All my three previous rigs had Atwood heaters which didn't have anodes...just the plastic plug you had on your pup.
