03-28-2015, 12:17 AM
Help! First night in new Rockwood and I have a leak!
I hate my introduction to be a cry for help, but desperate measures call.... I bought a new 2013 Rockwood 2907SS ( yes new, it sat on the lot for two years and i got a great deal). Dealer supposedly did a three our PDI two days ago. However I am dry camping on my first night out. Turn on the pump and I have a leak that only come when pump is on and or gray water is draining. Comes out of both corners of the rear of the trailer. Compartment around the waterpump and fresh water tank are dry so I figure it has to be something to do with grey tanks but don't know where to start.... Any help greatly appreciated!
03-28-2015, 01:45 AM
Are you sure your low point drains are closed? Your post says the dealer " supposedly" did a three hour PDI. We're you there for it? Just wondering.
If your pump and area around it are dry, something has to be open or cracked.
Wish I could offer more advice, but I'm not familiar with your model. Good luck. Somebody on this forum will have a better answer for you.
03-28-2015, 04:55 AM
If you can post a picture of the water leaking, we can help you identify the leak.
crunchman
2015 F-250 FX4
03-28-2015, 05:23 AM
First off welcome to the forum!
Wonder if the grey tank drain pluming is connected properly to the tank. Might want to lower the underbelly cover and have a look.
As said, pics would help
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
03-28-2015, 09:30 AM
Thanks everyone. They told me they check the tanks and all lines before I got there. Back left corner of bumper, comes out from under the molding [ATTACH]72347[/ATTACH. Leaks when pump is on kitchen sink in use. Small leak in water heater will tighten that plug.
03-28-2015, 10:09 AM
Welcome to the forum, sorry to read about your trouble. I don't think the dealer did much of a PDI and now you have to go through it under fire so to speak. I'm not familiar with your unit so not any help here. Once you do get the bugs worked out I'm sure you will enjoy your camper, good luck.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
03-28-2015, 10:28 AM
RV plastic drain pipe joints sometimes loosen over time. Go over all drain pipe connections (usually black) under the sinks and other accessible locations. Make sure each one is tight - if not, then hand tighten. I check mine every season especially after winter storage.
Also while you are in those areas have someone else open the sink cold / hot water valves / handles and check for leaks.
Hopefully it's not a split or fractured pressure pipe or bad crimp connection. Since you mention it's a new old stock RV, it likely went through a few freeze / thaw cycles if it was exposed to freezing temps before you owned it.
The PDI may of been performed but it may overlook some key items which may unfortunately be discovered on your maiden voyage.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
03-28-2015, 02:12 PM
See if you can check the lines & connections, there may be a crack or a loose connection. How far are the tanks from the back of your rig? If they are near the back it could be a leak or loose connection. Since it sat for 2 years you may want to check the gaskets they could be dried out. Hope this helps.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
03-29-2015, 09:43 AM
Radioman
I noticed you said a small leak from the HW drain plug. BE CAREFUL, don't over tighten that plug. If you do, you could strip the threads, then you'll have a much bigger problem.
Radioman
2005 Ram 3500 4X4 Diesel
2013 Silverback
Yuba City, CA. 95993
03-29-2015, 09:50 AM
Your "drain plug" on your hot water tank looks like an anode.. When you're home, drain the water system and remove it. Inspect it to make sure it is in good shape.. Then retape it (teflon) and re-install it, making sure to not over tighten as preciously mentioned..
Camped: 2023 (Days/Nights) - 34/27
2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
03-29-2015, 10:13 AM
Thanks for everyone's help. I am going to try these recommendations when I get home
