Old 06-20-2019, 01:09 PM   #1
Help! Forecast for 25 degrees tonight
We just got to Yellowstone on our first ever trip and the forecast is for snow and a low of 25 degrees. Iím at a full hookup campsite. Iím not sure what I can do to prevent damage from freezing. I plan on disconnecting water for the night and my fresh water tank is already empty. I can leave the furnace on and all the cabinet doors open for air flow, any other ideas tips?
Also I think I have tank heating pads? I have no idea what they do but I think the switch is in the bathroom because thatís the only switch I canít figure out a use for.
Thanks in advance!
Broomshanker is offline   Reply With Quote
Old 06-20-2019, 01:25 PM   #2
You should be fine. Looks like forecast for West Yellowstone has only 7-8 hours below freezing. I would fill fresh tank to at least half full so that you have enough mass that it won't freeze. More water in your tanks will keep it from freezing up.
Try to figure out the tank heaters if you can. Keep the heat on and comfortable and the lower cabinets open when you go to bed.
MtBiker is online now   Reply With Quote
Old 06-20-2019, 01:36 PM   #3
Yep, you should be fine running the furnace and the tank heaters.
Remember, things don't freeze the instant the temperature gets to 32ļ.
It takes hours for the mass to cool down enough to begin to freeze and many more hours for things to get solid enough to cause harm.
Put water in your fresh tank and unhook your city water connection and drain your hose/regulator/filter. (if equipped)
Use the water in your tank to flush the toilet and so forth.
If you have an electric space heater, you can supplement your heat with that for the night. Just don't set it so high the furnace doesn't run as many rigs have ducting that helps heat the underbelly off the furnace.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 06-20-2019, 02:02 PM   #4
Fulltime family RVer
Personally, I'd put some water into the fresh water tank so you are able to flush and whatnot.
ependydad is online now   Reply With Quote
Old 06-20-2019, 02:09 PM   #5
PPST Wannabe
kenandterry's Avatar
I agree you want some (1/3 full) water in your fresh water tank.
Turn on the heater pads. You should be fine for an occasional below freezing.
BTW.....I always keep minimum 1/3 to 1/2 on board just in case of needing water while traveling AND, although it only happened once, our park lost its water supply to customers because of their pump failure. We had enough for our needs while it took over 8 hours to fix.
You never know.....even full service sites can have their problems.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 06-20-2019, 05:38 PM   #6
Thanks for all the replies, I figured it wouldnít be a huge deal but I wanted some reassurance!
Old 06-21-2019, 01:50 PM   #7
Having been full timing for 16 years, the most reliable method we use when it drops below freezing is to let the water run in the bathroom sink (the kitchen sink splashes too much) just a bit more then a trickle. Here at Mesa Verde NP, it fell below freezing almost nightly up until the first of June
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
