Old 05-12-2011, 08:05 AM   #21
GM
bclemens's Avatar
Just went out on the line to have a look.
Go to the camp side compartment, 2nd from the back. That's where your water filter is. Take off the little black door inside that compartment to access the water pump. There is the blue water line with a little chrome valve....that valve is open. Close it, you're good to go.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-12-2011, 08:10 AM   #22
janegraves's Avatar
found those valves and turned one, it cut water off to sink, etc. turned other and don't know what it did, but water still drained as I filled it.
janegraves is offline   Reply With Quote
Old 05-12-2011, 08:21 AM   #23
GM
bclemens's Avatar
The cap is not missing, we use valves instead. The hot line has a cap that we put on for the air pressure test.
Old 05-12-2011, 08:22 AM   #24
GM
bclemens's Avatar
Should be the lowest valve on the blue line. The others are for bypasses.
Old 05-12-2011, 08:26 AM   #25
Herk7769's Avatar
Why not on my Flagstaff?
HAM CALLSIGN - KC3FFW
Old 05-12-2011, 08:26 AM   #26
janegraves's Avatar
is it one of the valves under the bed?
Old 05-12-2011, 08:39 AM   #27
janegraves's Avatar
I will look for the valve by the water heater when I get home from work today. Unfortunately, I have to work so I can pay for this new toy.
Thanks for all the responses. I knew I could count on this forum to resolve the problem.
I will let you know how it works out.
Old 05-12-2011, 08:45 AM   #28
GM
bclemens's Avatar
That's a whole other division, they do things differently.
Old 05-12-2011, 08:54 AM   #29
Happy to Be Camping
Shawomet3's Avatar
Location: We live in Rhode Island, but our hearts are in New Hampshire
In my sunseeker, there is a drain valve near my tank (under bed) that is the drain. I also have caps outside. Just look at your tank if you can and follow the lines out-it's small, but you'll see it.
Hope this helps.
Shawomet3 is offline   Reply With Quote
Old 05-12-2011, 09:34 AM   #30
GM
bclemens's Avatar
If you can see the line that water is coming out of, it should be easy to follow that line up to the valve.
