Old 05-11-2011, 06:26 PM   #1
janegraves's Avatar
Help: Just received delivery. Water tank help.
I'm putting water into the fresh water tank and it is running out the bottom. The guage says E and the manual is useless. Sunseeker 2300.
janegraves is offline   Reply With Quote
Old 05-11-2011, 06:40 PM   #2
Send a message via Skype™ to scubieman
There is a plug.for where it runs out. Dealer should of told you where it is before you left.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-11-2011, 06:40 PM   #3
Koodog's Avatar
Did you close your drain valve on the fresh water tank? Look under tank and you will see a valve(level) which is used to fully drain tank.
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
Koodog is offline   Reply With Quote
Old 05-11-2011, 06:52 PM   #4
janegraves's Avatar
underneath there are 2. one red has a screw cap on it one blue that don't have any cap. blue one is draining. had it delivered and delivery people didn't know anything. just said look in manual
Old 05-11-2011, 06:55 PM   #5
The red is for hot water low point drain , the blue is for cold water low point drain . Nothing anyone can do till you find cap. It could be in your water heater cover . Or check all drawera inside. Or make trip to local rv shop tomorrow for new one.
Old 05-11-2011, 07:00 PM   #6
janegraves's Avatar
no place for a cap on the blue one. it just ends.
Old 05-11-2011, 07:05 PM   #7
Someone mess up and not put end on? If it runs out right away I would yell at dealership. Make them fix it.
Old 05-11-2011, 07:22 PM   #8
janegraves's Avatar
rv direct in NY. I'm in NC. Oh well. Will try pressurized water and see if it works until we figure out the problem. Meanwhile, I'm having a glass of wine inside my new RV.
Old 05-11-2011, 07:25 PM   #9
Im jealous.
Old 05-11-2011, 07:50 PM   #10
tking01_2000's Avatar
Probably a valve by the water tank that s where mine is
tking01_2000 is offline   Reply With Quote
