Old 03-08-2019, 07:56 PM   #1
Help me assemble a plumbing tool kit / must haves
Hello all,
We are total RV newbs. Ive realized that rv camping entails becoming a truck driver/electrician/ plumber/ mechanic so Ive embraced it.
Our plumbing is mostly the pex / blue/red plastic piping. What would be the must have spare parts and tools to keep n the RV?
2019 Cruiser Stryker 2613
2019 F 350 6.2 CCSB 4.3
14k Equalizer
Deanm is offline   Reply With Quote
Old 03-08-2019, 08:03 PM   #2
I carry zero. The beauty of pex is how great it is. garden hose washers are the only plumbing parts I carry.
Kimber45 is offline   Reply With Quote
Old 03-08-2019, 08:27 PM   #3
NMWildcat's Avatar
Flex Tape for emergencies. Shouldn't have problems with pex or fittings while on the road. Most other connections are hand tightened, so tools aren't really necessary. You will never have enough spare parts to have the one you actually need. I quit carrying any spare parts years ago.
I always carry water pump pliers just in case though. I probably use my multi-tip ratchet screwdriver set the most. Make sure it has lots of tips, including the square and star ones.
Scott and Liz - Southern NM
Old 03-08-2019, 08:35 PM   #4
Hoglou's Avatar
Pex
Get to Lowe's and pick up a 6' run of 1/2" pex, some razor style cutting shears, two shark bite 1/2" connectors. No tool needed to assemble but a tool is needed to separate connectors if you move them once installed. You can now fix about any water issue youbbcan reach. Consider if you like your hot and cold low point drains. Swapping those out for real valves is a popular first mod....
If you are adventurous you could get a pex crimp tool, they are fun. Two types are made; 1) band style and 2) rachet band. Different tool for each, worth a walk thr plumbing. Or the toy store DW calls it.. Plus you get to upgrade to brass junctions as you make improvements.
I carry a 24 long tool box, so I cut my pex peices to 23".. but then I'm that guy who two is one, and one is none when it comes to tech support for camp systems on the road.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-08-2019, 09:56 PM   #5
BuzzWolfAR's Avatar
X2. I don't carry any plumbing stuff. A pair of plyers has fixed everything I needed to fix.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 03-09-2019, 07:10 AM   #6
nomad297's Avatar
There is so much to plumbing that CAN go wrong, but probably WON’T. I am a plumber and I carry tens of thousands of dollars worth of tools and materials on my work truck, but there still always comes a time when I don’t have something I need. I would need to drive a tractor/trailer to (almost) ensure I didn’t have to run by the supply house for that one thing I don’t have.
For the hand tools I use the most at work, I have a large Carhartt tool bag that I keep on my work truck and carry into every job I go to. I keep a “clone” of this bag and its contents on my personal truck that goes camping with me. The main purpose of this bag of tools is as a backup in case my other bag “goes missing”. If this happens, I will have everything I need and not lose time for work. The secondary purpose for this bag is that almost every tool in it is something I can use to fix almost anything in my camper. So, I do have just about every tool I could possibly need for fixing plumbing in the camper, but I do not carry any materials — it just doesn’t make sense — there’s too much stuff that might be needed that can usually be picked up at any hardware store or Walmart.
If you would like me to make a list of every tool I carry in my bag, I will do that for you. Let me know.
Bruce
nomad297 is online now   Reply With Quote
Old 03-09-2019, 07:24 AM   #7
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
I carry a variety of screwdrivers (including the square, hex and star), pliers, a rubber mallet (primarily for driving stakes into the ground to secure my satellite dish), vise grips and water hose washers - plus tire-changing tools. Oh, and an inexpensive ratchet/socket set in a black case.
That's pretty much it for me. As has been said previously you'll never have all the right tools if you actually encounter a significant problem. Just hope you're not too far from a decent hardware/tool store if/when that happens.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 59
rjshiflet is offline   Reply With Quote
Old 03-09-2019, 07:34 AM   #8
Only thing I've ever needed to fix plumbing related issues was a wrench, pliers, square head screw driver. That's all I've carried since 1984
TheWolfPaq82 is offline   Reply With Quote
Old 03-09-2019, 07:51 AM   #9
Herk7769's Avatar
Originally Posted by Deanm View Post
Hello all,
I carry an assortment of hose fittings (Ys, a 4 outlet manifold for Goshen, etc.), gaskets for water and sewer hose, Channel lock pliers to tighten connections, PEX shear, a 3 foot length of PEX, and a few SharkBite fittings for a quick repair. I used to also carry a spare toilet valve, but I have a different model toilet now.
ID:	198341   Click image for larger version
ID:	198342   Click image for larger version
Name:	4 way brass manifold.jpg
ID:	198343   Click image for larger version
ID:	198344   Click image for larger version
Name:	hose to NPT.jpg
HAM CALLSIGN - KC3FFW
Old 03-09-2019, 07:58 AM   #10
Murphy's Law: "No matter what or how much you carry, you will not have what is needed."
plumbing
