Old 05-17-2011, 07:07 PM   #1
Shellback67's Avatar
HELP missing water pump
I bought a 2005 Grand Surveyor and can not find the 12volt pump. This is standard isn't it?? Dealership closed for the night today.
Shellback67 is offline   Reply With Quote
Old 05-17-2011, 07:15 PM   #2
sherdep's Avatar
If you fill your fresh water tank and turn on the pump - it will make it easier to locate - the pump is usualy near the water filter
If you camper doesnt have one -
camping world sell's them - there are diffrent flavor's of pumps
you will need to know the GPM (Gallons per Minute) of your old pump
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-17-2011, 07:17 PM   #3
I just can not find the physical location of a pump or switch.
Old 05-17-2011, 07:20 PM   #4
Oakman's Avatar
Put some water in the fresh water tank, turn on the pump, open a faucet, follow the sound to the pump. If you don't hear anything the pump is either broken or missing. I've yet to see a camping trailer without a pump. On many units the pump switch is a red button on the holding tank indicators.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-17-2011, 07:24 PM   #5
sherdep's Avatar
the water pump switch is usually located on the panel that allows you to check the levels of your tank (Black, Gray, Fresh and Battery)
I do not own the same unit as you so not sure on location
Old 05-17-2011, 08:26 PM   #6
Thanks for reminding me of the red switch on level indicators. I found this and heard the pump run briefly and think I know where to look. The pump was located under the sink on my old unit but this one is hidden behind a panel I need to remove.
Old 05-17-2011, 08:30 PM   #7
sherdep's Avatar
glad to see you may have located it
Old 05-17-2011, 08:40 PM   #8
Stevea1956's Avatar
If it's anything like our TT there are 2 screws that hold that panel to the floor and the pump and filter are behind it.
It'll be a good time to replace your filter if you have one. The Whirlpool filter cartridge from Lowe's worked in mine.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 05-17-2011, 08:46 PM   #9
sherdep's Avatar
I tried a filter from Home Depot - it fit but I lost water pressure so had to get another new one - I think the one I bought had a purple ring and was 1.5 Micron - I noticed the factroy one you can look straight thru a hole in the middle of the filter - the one from Home Depot couldnt see any light.
Good Idea on replacing filter but just putting the info out there on the filter cause depnding on the filter you get - you may reduce you water pressure inside the camper
