Old 07-29-2013, 08:31 AM   #1
Unhappy help newbie light a water heater
Hubby changed propane tank and now we have no hot water. What do we do??
Grammyof15 is offline   Reply With Quote
Old 07-29-2013, 08:37 AM   #2
wmtire's Avatar
I am assuming you are running the water heater off of propane (not 120 volt electricity) and that it was working before your husband changed the tank.
When you say changed the tank...do you mean he switched over to another propane tank, or had one refilled? If changed over to another one, are you sure it has propane in it?
Do you have dual propane tanks?
Do you have propane to other things...stove, heater?
Have you purged the air out of the line, by turning on your stove?
Sometimes you will need to shut the valve back off on the propane tank and open it up real slow.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-29-2013, 08:39 AM   #3
Originally Posted by wmtire View Post
I am assuming you running the water heater off of propane (not 120 volt electricity) and that it was working before your husband changed the tank.
Stove works and has worked since it was changed but now no hot water
Old 07-29-2013, 08:44 AM   #4
wmtire's Avatar
Do you have the water heater switch turned on? If you have a DSI (direct spark ignitor).....it has a lockout built in. If you had air in the lines and the DSI failed to ignite the propane after a few attempts, it locks the whole propane system down to the water heater. This is a safety feature.
Turn off the water heater switch and wait one minute, then turn it back on...to reset it.
Old 07-29-2013, 08:51 AM   #5
TURBS's Avatar
I'd also recommend even tho the stove works shutting off tank valve then slowly turning back on.
Old 07-29-2013, 08:51 AM   #6
wmtire's Avatar
Not knowing what water heater brand/model you have, my answers are generic in nature.
You could also have a pilot light water heater.......that you would have needed to relight the pilot light for it to work. Many of the newer water heaters don't have the pilot light though and use the safer DSI.
Can you tell us more specifics on how you have used the water heater in the past and the steps you go thru?
Old 07-29-2013, 06:38 PM   #7
Unhappy
Thanks, did that too, and someone said to wait 5 min. May have to call the repairman
Old 07-30-2013, 04:31 AM   #8
http://www.forestriverforums.com/for...ore-36197.html
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 07-30-2013, 06:11 AM   #9
dmf564's Avatar
Like many others have said already. You probably just have air in the line. Just be patient. If you are trying to light the pilot light, it takes some time to get gas to flow through it as it is a very small tube and may take a few attempts. I have used a long tube lighter to warm the flame sensor enough that it will allow gas to flow through the main burner tube. Once its hot ( the sensor) just hold the lighter in the tube, light it and then turn on the WH bypassing the pilot setting on the switch and going straight to the ON setting on the switch. The main burner should light and the pilot light will light off of it once the air is out of the line. Just do not put your face near the burner tube, just so you keep your eyebrows. This will only work if you have a manual start WH. IF its an electric start. You'll just have to keep resetting the WH with the switch in your camper until it lights on its own as others have said. Be patient!
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 07-30-2013, 06:14 AM   #10
Herk7769's Avatar
My money is here. Since you ran out pr propane, the water heater is most likely in lockout.
HAM CALLSIGN - KC3FFW
heater, light, newbie, water, water heater
