Old 05-09-2015, 09:14 AM   #1
Help no hot water, camping right now
Can someone help me. I cannot get the tank to start (propane or electric) I have a pic attached. Can someone tell me how these valves should be?
Anyone know why there is a valve between the red and blue??
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-09-2015, 09:22 AM   #2
Your valves are correct,open the O/S w/h door and turn on the switch! Youroo!!
youroo is online now   Reply With Quote
Old 05-09-2015, 09:22 AM   #3
Your valves look right.. The one on the right is the hot water tank bypass and should be closed when camping. It is used to winterize your RV..
The bottom one is the cold water inlet and the top is the hot water outlet.. Both need to open during normal use, which they appear to be..
Are you hearing water entering the tank with your pump on and city connection? Is it just not making hot water at all? Luke warm water? No water at all?
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 05-09-2015, 09:25 AM   #4
The valves shown are correct to get hot water flow. If you turn all the valves 90 they will be in the bypass mode to add antifreeze for winterizing.
Make sure you have a full water heater tank by flipping the pressure relief valve at the top of the water heater. There is a 110V switch on the lower lh side of the compartment. As for the propane side, open the propane tank valve slowly and then go light the stove burners to help purge the air out of the lines. Next step is go to the control panel and turn the water heater DSI switch to on. You will hear the water heater trying to light. IF after it tries 3 times without lighting, you have to turn the switch of and then on again and it will repeat trying 3 times...
Old 05-09-2015, 09:37 AM   #5
All set. Thanks all. The bypass I turned to the position you see in the pic. And the propane started right up.
I'm going to use electric now to save propane.
What was weird was we had hot water yesterday with that bypass open..
Built-in Controller
Old 05-09-2015, 09:48 AM   #6
Flybob's Avatar
You will get hot water with the center valve turned on. The problem is that you will be mixing hot and cold water and will get warm water . This is no different than turning on both hot and cold water at faucet to mix them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-09-2015, 09:59 AM   #7
I love this forum. Ty everyone
Built-in Controller
Old 05-09-2015, 01:04 PM   #8
5thwheel's Avatar
Problem solvers
You will always get the "right" answer on these forums, quickly.
5thwheel is offline   Reply With Quote
Old 05-11-2015, 06:30 PM   #9
Long Islander
The two outside vaulves should be on and the middle one off. Good Luck.
flharley is offline   Reply With Quote
camping, hot water, water
