Old 02-15-2016, 07:41 AM   #11
Witch Doctor's Avatar
Originally Posted by AquaMan View Post
This usually solves the problem, although it could happen again. It's not necessarily a flaw in your system, but just something that happens every once in a while. It can happen to any of us. If it happens on a regular basis, then get it checked out. A pump is an easy thing to replace and or take apart and clean.
X's 2 it has happened to me a couple of times just ran the pump by itself and it reset or cleaned the diaphane valve that lets it by pass. Pretty common problem if you have the city running and turn the pump on at the same time by mistake....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-18-2016, 12:49 PM   #12
Peytonlover_18's Avatar
Water pump issues
Now my water pump is only working if disconnected from city water. But before the pump froze, it was working both ways. Anyone know what this might be?
Peytonlover_18 is offline   Reply With Quote
Old 02-19-2016, 09:59 AM   #13
help overflowing holding tank
Nothing wrong, as long as the city water is over the set pump pressure usually 40 psi it will not run. Occasionally when at a park the water pressure will drop so low that the pump will run to bring the system pressure back up.
We don't turn our pump on when connected to the city supply, but we always keep at least 1/2 tank of fresh water. We have been in parks and the water got shut off, so we always have a supply for at least a day
Rich5117 is offline   Reply With Quote
Old 02-26-2016, 12:33 AM   #14
MNtraveler's Avatar
X2 - the line is pressurized so the pump (which runs only on demand) won't run. It should be turned off when on city water.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
