Old 02-11-2016, 07:35 AM   #1
sparky
help overflowing holding tank
why is the city water connection filling my fresh water holding tank causing it to overflow?
ravn53 is offline   Reply With Quote
Old 02-11-2016, 07:41 AM   #2
Pickin' & Campin'
The check valve in the water pump likely has a piece of debris caught in it causing the city water to back flow into the tank.
Also, some models have a valve that allows you to fill the fresh water tank while connected to city water. It could be leaking or positioned incorrectly.
As search of forum on this particular problem will bring up tons of threads about this very subject.
Please include specifics about your unit when posting so we can better help you with problems.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 02-11-2016, 08:01 AM   #3
Looks like he has a Wildcat! 2016! Youroo!!
Old 02-11-2016, 10:18 PM   #4
sparky
yes it is a 2016 wildcat 26fbs is this a common problem
Old 02-13-2016, 10:08 PM   #5
Could you provide a little more info, on your Wildcat control panel where you hook up the city water hose is there a valve to change from city to fresh water, or are there two separate connections. My Silverback only has one connection I'm not familiar with the new Wildcats. This may help to pinpoint your problem and find a solution.
Rich5117 is offline   Reply With Quote
Old 02-14-2016, 09:49 PM   #6
sparky
wildcat 26fbs TT 1 conn. for city and 1 for blk tank flush I think it might be a clogged fresh pump blow by
Old 02-14-2016, 09:50 PM   #7
sparky
no valve
Old 02-14-2016, 10:12 PM   #8
Ravn53 think you are correct sounds like a bad check valve between the city and fresh water system. You might try turning off the city and running the pump for the fresh water tank it might free it up if it's stuck or clogged with something. If not sounds like a warranty repair.
Old 02-15-2016, 06:54 AM   #9
sparky
tried using pump and it seems to have solved it time will tell. thanks for the help to all. will keep you in the loop.
Old 02-15-2016, 07:27 AM   #10
AquaMan's Avatar
This usually solves the problem, although it could happen again. It's not necessarily a flaw in your system, but just something that happens every once in a while. It can happen to any of us. If it happens on a regular basis, then get it checked out. A pump is an easy thing to replace and or take apart and clean.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
tank
