Old 02-21-2015, 03:51 AM   #1
Help, plz? Water hose attachment outside...
We have a 2000 Forest River Spinnaker w/2 pull outs
Model: number 33RLBW, 35' long.
What does the water hose attachment, on the outside underbelly, go to? It is on the toilet side but a bit more to the front of the fifth wheel, away from the toilet.
And I ask because it is leaking and we cannot figure out what it is?
Is it a hookup for a hose to have an outside shower possibly?
Or maybe the water heater, leaking?
Any help would be greatly appreciated!
Thank you.
angelnthsky is offline   Reply With Quote
Old 02-21-2015, 04:11 AM   #2
I'm not sure on your particular rig, but it sounds like a low point drain used to empty your water lines for winterizing. Typically there are 2 fairly close together. One for hot water, and one for cold, but on an older rig.. I'm not sure. It's possible there may be only 1 for the fresh water tank.
Is it threaded? If not threaded then it's possible it could be some type of drain for your fridge or air conditioner. In that case, then you would want it to be 'leaking'.
rana is offline   Reply With Quote
Old 02-21-2015, 05:50 AM   #3
fonzie's Avatar
Post a picture if you can
Fonzie
Old 02-21-2015, 07:07 AM   #4
Thank you.
Being a (2000) year unit it could be a (Mod/Addition) that has been added for (?) reason! Since it is (Threaded) very well (could/is) a Black Tank flush! Hooking a hose to it without knowing where it goes could give a (Shower you Don't Want)! Youroo!!
Old 02-21-2015, 02:01 PM   #5
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Hose connection
It may be a tank Flush connection for the black water tank. Can you see the black tank? Check the tank and see if there is a hose installed on the tank near the bottom.
Eaglelover is offline   Reply With Quote
Old 02-21-2015, 02:57 PM   #6
Timex's Avatar
Here is what my Low Point Drains looked like before and after.
Hope this helps the OP figure things out.
ID:	70009   Click image for larger version
ID:	70010   Click image for larger version
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 02-21-2015, 09:57 PM   #7
Jim
On my 05 Cardinal, these are two low point drains. Underneath between the hot water heater and front bathroom.
JimP is offline   Reply With Quote
water
