Old 04-30-2016, 08:23 PM   #21
Wobbles's Avatar
Originally Posted by gspot01 View Post
Ok, I removed the drain pipes to reassess the situation. It looks like I can just reapply whatever the sealant is (any recommendations?) to the black water pipe, shove it back in, and tighten the clamp.
Oh, and the sealant feels just like old chewing gum. Have no idea what it is.
The problem is going to be the grey water pipe. Don't know of you can see it in this photo, but the end broke off in the 90-elbow it connected to. I've somehow got to figure out a way to replace this piece and the elbow, both of which are still glued to other pieces which I would like to salvage if possible.
Sent from my SD4930UR using Tapatalk
I looks to me that one part(small length with the o-ring) was meant to be mated inside the tank, and the rest was glued on like normal pvc. Mabey that was meant to be a flex point. I do not know but wonder if that was supposed to allow for some movement less than what you did to it. Good luck with it but think on it before there is stink in it.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 04-30-2016, 08:26 PM   #22
2012 Solera
Originally Posted by OldCoot View Post
For the smaller pipe, get a rubber coupler that has 2 hose clamps.
X2. They have them at our local Home Depot. You can abs glue a coupling to the small pipe to get it to the same diameter as the elbow, if you can't find a rubber coupling that necks down.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-30-2016, 08:37 PM   #23
jtstromsburg's Avatar
X3 fernco coupling
Name:	ImageUploadedByForest River Forums1462066616.498026.jpg
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-30-2016, 08:45 PM   #24
The rubber couplings will stretch enough to connect to the elbow. I would also smear some Gorilla glue on the inside of the coupler to make it slide easier. Just don't get it on your hands as it is extremely difficult to get it off skin.
Old 04-30-2016, 08:50 PM   #25
Pickin' & Campin'
Originally Posted by jtstromsburg View Post
X3 fernco coupling
Attachment 106567
X4 on the fernco for the smaller grey pipe.
You won't have to cut or remove any of the broken pipe still in the elbow.
As mentioned, if you can't find a reducing fernco, just cut the smaller pipe so a glued on coupler will match the elbow.
Just shove the whole thing back up to mate where it was originally and tighten the hose clamps on both sides of the fernco.
There's no pressure in the drain pipes so a fernco will work just fine.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-30-2016, 09:05 PM   #26
They make a drill bit to drill out the inside of the fitting. If you have a friend who is a plumber he should have them. Really easy fix with that. A fernco will work to but if I had the drill bit I would use it.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-30-2016, 09:14 PM   #27
Y'all rock! That's some good info there. The only thing I'm a little unsure about is whether there's enough of an extension on the elbow to secure the fernco clamp. I'll have to go outside and look. If that works, however, you couldn't ask for any easier!
Sent from my SM-T320 using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 04-30-2016, 09:48 PM   #28
They also make a 90 degree fernco. You could cut off the old 90 and replace it with a fernco.
2016 Flagstaff 23lb
Old 04-30-2016, 09:55 PM   #29
Iggy's Avatar
Sorry to see your accident which can be fixed.
The bright side is your tanks were empty.
Old 04-30-2016, 10:44 PM   #30
CaptnJohn's Avatar
X2. 30 - 40, even 2 gallon of black tank contents spread by 20 gallon of gray water.... very lucky.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
