Old 04-30-2016, 03:41 PM   #1
Help! Sheared off sewage pipes
Stupid newbie mistake: ripped off the black and grey water drain pipes backing it into the driveway for the first time.
I'm going to try to fix this myself. I've had a little experience repairing pvc for underground sprinklers, so I know just enough to be dangerous.
Can anyone advise me on how to approach this?
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 04-30-2016, 03:46 PM   #2
Ford Idaho's Avatar
O U C H!
Larger one looks easy enough, upper one looks like it will need a new fitting and perhaps some pipe work.
I would approach that job on my creeper.
I would also look at some way of installing a skid plate.
Old 04-30-2016, 03:49 PM   #3
Yeah, it's a PITA for sure. Went over a curb. Is this regular PVC that I can get from the Home Depot? How do I get the connections I want to reuse apart?
Old 04-30-2016, 03:54 PM   #4
Ford Idaho's Avatar
Yes you can get the stuff you need at Lowes or HD.
Dremel with a cutoff wheel and or grinding stones set speed to a lower setting so as to not melt the plastic.
Old 04-30-2016, 03:57 PM   #5
What about all that stringy putty -like gunk? Do I need to get that off? Any recommendations?
Sent from my SM-T320 using Tapatalk
Old 04-30-2016, 04:03 PM   #6
Ford Idaho's Avatar
I would remove as much as possible to keep it from getting in or on the drain valve.
With out knowing what it is for sure I would take a bit of it and see what breaks it down.
Brake cleaner, Goop off, or what ever will not harm the plastic.
Old 04-30-2016, 04:12 PM   #7
Alright, thanks! Time to get to work!
Old 04-30-2016, 04:14 PM   #8
Ford Idaho's Avatar
Old 04-30-2016, 04:18 PM   #9
Brother Les's Avatar
These should have been glued in with pvc glue....why the hose clamp?
Brother Les
Old 04-30-2016, 04:24 PM   #10
I know you don't feel this way right now...but you are really lucky. Looks like you didn't break anything (especially the tanks!!!) and the tanks were empty. Mine weren't and I broke a bunch of ABS. Looks like plumber's putty. Clean it off with Goof-Off and reinsert the fittings and tighten them down. The black is clearly a simple hose clamp to the tank, can't see the grey. I bet FR did it that way so that you aren't faced with replacing a tank or two.
Either way, consider yourself luck that you don't have 40 gallons of black tank contents spilling out on the driveway.
2015 335DS
ScottBrownstein is offline   Reply With Quote
