Old 04-13-2014, 06:25 PM   #1
IHDRIDER00's Avatar
Help!! Toilet stopped-up
Hi, Help. 04' All American Sport 36CK 5th Wheel Toy Hauler. Toilet will backup. Black tank is empty. New to RVing. Took 4ish trips last yr. no problem. This first trip the toilet backed up. It's not a straight shot to the black tank, so you cannot see straight down. There are two 45's in between the toilet and the tank. I was hesitant but I used a snake to free things up. I was very difficult, a lot of resistance, I thought it would be a straight shot. But It worked. It stopped up again. Thinking the dump valve was clogged I went under the RV and pushed in the black tank it was empty. It clears every time you snake it but something's not right. Is there a valve going into the tank, a piece of pluming that may have gotten loose? Help, Mike
IHDRIDER00 is offline   Reply With Quote
Old 04-13-2014, 06:47 PM   #2
rburns4147's Avatar
You could try to pour clear water from a bucket down the toilet (holding the flush valve open). If water doesn't pass, maybe something has fallen down there and lodged in one of the 45 degree fittings. One of those wall inspection cameras would be a handy tool if you had access to one. I have never pulled a toilet but you might have to so that you can get a better look. I hear that it is fairly easy.
There should not be a valve under the toilet and the fittings should be glued PVC, like house plumbing. Just my thoughts. Good luck.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 04-13-2014, 07:08 PM   #3
Oaklevel's Avatar
Maybe a small "mountain" just inside of the tank. Try one of the "hose" tank sprayers that you put down into the toilet. They work much better than a snake.
Good Luck !!!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-13-2014, 07:14 PM   #4
Pull the toilet, 2 nuts and the water connection, use a flashlight and a mirror on a rod and take a look. You might have a tank cutout just turning and blocking the pipe. If that's the case, a wire finger clamp might be used.
Old 04-13-2014, 07:26 PM   #5
dmf564's Avatar
I had that problem with my grey tank. Turned out it was the wood floor cut out blocking the pipe for the drain on the grey tank. So I'm betting that is your issue. Follow OldCoots steps to solve your issue.
Sent from my DROID BIONIC using Forest River Forums mobile app
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 04-14-2014, 03:42 PM   #6
IHDRIDER00's Avatar
Thanks All, Will pull the toilet this weekend. Is there any gasket, seal? I'll post results. Thanks Guys, Mike
