Old 04-02-2013, 03:52 PM   #11
Your city water hookup goes directly to your pipes and faucets and is used in campgrounds. Your fresh water tank can be used when you are somewhere that doesn't have water to hook up to. Like overnighting in a parking lot or for flushing your toilet when traveling. City water does not use the water pump.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-02-2013, 03:55 PM   #12
CampingQueen
Oh, and NEVER use the same hose to connect to fresh water (or fill the fresh tank) that you use to flush or clean your sewer hose/tanks!
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 04-02-2013, 09:12 PM   #13
So what's it mean when u hook up to ur citywater hook up and still have no water
brat1598 is offline   Reply With Quote
Old 04-02-2013, 09:13 PM   #14
So what's it mean when u hook up to city water connect and still get no water
Old 04-02-2013, 09:20 PM   #15
Turn the faucet on at the house?
Inlet screen blocked, pressure valve frozen shut? You will just have to start investigating. Did you get water in the fresh water tank and try the pump? Work on one problem at a time is the best advice I can give you.
Old 04-03-2013, 03:57 AM   #16
No haven't tried fresh water tank yet because I had work just gettin off lol but ima try it when I get up today and ill let u know what happens thanks for the help
Old 04-03-2013, 06:36 AM   #17
AquaMan's Avatar
Not sure if this has been covered or not, didn't read some of the lengthy replies. Look for winterization bypass valves around the pump. If these are turned off, you wouldn't get water from tank or city possibly. That would be my guess.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-04-2013, 09:13 PM   #18
Well I filled it up and ran it but only got water to come out the bathroom sink. Nowhere else
Old 04-04-2013, 09:18 PM   #19
PhotoMaster's Avatar
If you're getting water in the bathroom sink I would think you just need to turn off the bathroom sink and let the others run longer. (one at a time)
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 04-04-2013, 09:40 PM   #20
Flagstaffer06's Avatar
Check the screens at each faucet. Remove the screens and try running the faucets. If you have it in one sink it is obviously getting in the camper. Also, possibility of shut offs at each sink. It is doubt full but possible. The best advice is above, one issue at a time. Good luck!
Flagstaffer06 is offline   Reply With Quote
