Old 06-23-2012, 12:11 PM   #1
charmat's Avatar
HELP...water pump sucking air and won't shut off
Water pump does not allow a steady stream of water..keeps sputtering when we have the Fw tank on...nothing works ...also bunch of air and spits of water coming out of the hw heater. What is wrong??
charmat is offline   Reply With Quote
Old 06-23-2012, 12:44 PM   #2
PrairieBoy's Avatar
You have air in your system, likely from the hot water heater filling.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
2012 Dodge Ram 1500 4X4 CC Outdoorsman
PrairieBoy is offline   Reply With Quote
Old 06-23-2012, 02:37 PM   #3
VinceU's Avatar
Sounds like ok on shore connection?. Problem may be the pump direct suction hose valve at pump suction to allow antifreeze injection. The valve may be part open allowing some water from tank and air from injection hose. Look for valve near pump with short hose connected and three way valve (tank, short hose leads to pump) This assumes tank has plenty of water?
Old 06-23-2012, 04:06 PM   #4
TURBS's Avatar
Is the hw tank full yet?
Pump will fill hw tank first before you get any or much water out of taps?
Old 06-23-2012, 08:13 PM   #5
charmat's Avatar
We have the hose off the water pump and when we turn the pump on the water still spits and sputters coming out of the pump...could there be a problem from the fw tank to the pump?
Old 06-23-2012, 09:09 PM   #6
TURBS's Avatar
Is the tank full?
Old 06-24-2012, 08:26 AM   #7
PrairieBoy's Avatar
Do you have a valve on the pump suction side for winterizing the trailer and is it in the correct position?
If your water tank is full then the possible problems are:
-The vent to the water tank is plugged, not allowing water to exit the water tank
-The suction hose to the pump is plugged (doubtful)
-Pump is malfunctioning
-Suction hose has a loose fitting or hole
I would open the water fill access to your water tank and see if the pump will work. If not then I would drain your water tank, remove the line into the pump and see if it will suck out of a jug. Quite possibly the pump needs to be replaced. Hope this helps
Old 06-24-2012, 09:18 AM   #8
MilCop4523's Avatar
I have the same problem. 2012 Salem 27 RKSS. City water perfect. Tank water forget it. The tank is full (actually let it overflow out of drain line)
I took the line off the pump and replaced it with fitting and clear hose to a small pail with about 3 gallons of water in it.
Darn near run it dry in a minute or so.
Shut the pump off and then reconnected the line back to the white hose which feeds from the holding fresh water tank.
Turned the pump back on and NOTHING BUT AIR and a bit of water spray.
My manual says to fill the tank - done
Open all taps - done
Turn on the pump - Energised
And then start to turn off taps when a steady stream of water is seen.
I'm not sure but.... I would think that after 1/2 hour and 1/2 a water holding tank spit literally out of the shower, the kitchen sink which leaks at the pull out, and the bathroom sink that the air would be gone.
ID:	15650   Click image for larger version
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 06-24-2012, 09:26 AM   #9
fonzie's Avatar
Milcop have you tried to push pressurised air (10 -20 psi) back to the fresh water tank from the white hose that feeds your water pump. Maybe you have some restriction at the intake tube in the tank. Just a thought.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-24-2012, 09:36 AM   #10
PrairieBoy's Avatar
On our last 5th wheel the water pump is actually below the water level when the tank is full. I am forgetting that the on these new trailers and my new trailer as well that the water pump is actually above the tank and water level. If you are sucking air and have verified the function of the pump then it is likely that there is a loose fitting or hole in the suction line to the tank.
