Old 01-04-2012, 06:07 PM   #11
Mountainmanbob's Avatar
she has more experience with that waxie stuff
Originally Posted by jim44646 View Post
MM
A non-messy trick instead of greasing ball. Put a piece of heavy duty wax paper on ball before dropping receiver hitch on. Keeps things working smooth.
pulled a lot of trailers at work years ago
have never seen that
wax paper THING used
sounds like a good idea
since I'am the grease man around here
sounds like if I (we) use heavy duty wax paper
that would be a job for the wife
she has more experience with that stuff
my retirement life is getting easier !!!
thanks
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-04-2012, 06:13 PM   #12
jim44646's Avatar
Smile
thanks
Mountainman
Everyone use to laugh when I said I liked to grease my balls.
So now I waxpaper them.
jim44646 is offline   Reply With Quote
Old 01-05-2012, 04:42 AM   #13
whatever makes one happy
my wife goes out
and gets waxed sometimes
for me no thank you
I don't want any of that HOT wax
around anyTHING of mine !!
Mountainman
Old 01-05-2012, 10:58 AM   #14
RubenZ's Avatar
This is what you need.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 01-05-2012, 11:28 AM   #15
One of my low point drains is leaking on my Rockwood. The leak is coming from above the cap; between the plastic pipe and the fitting. How do I fix this?
rritchie98 is offline   Reply With Quote
Old 01-05-2012, 12:04 PM   #16
jim44646's Avatar
Check to be sure the pipe isn't cracked
Old 01-05-2012, 01:14 PM   #17
like Jim stated
check for possible cracks
if none
remove fitting
apply two or three wraps teflon-tape
re-insert
MM
Old 01-05-2012, 03:34 PM   #18
Originally Posted by Biggy
This is how I drain it after use...do I not need to be doing this every time I am done?
Biggy, you only need to drain it if it will freeze. I only drain mine in the winter months when I'm concerned about freezing temps.
2014 Flagstaff V-Lite 30WTBS
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab (SOLD, was a great truck)
smithmdsmith is offline   Reply With Quote
Old 01-07-2012, 10:57 PM   #19
I bought a use SV-291 this past year. It had a leak one of the low point drains. Mine had a gasket on the one that did not leak. Went to HD to get a replacement gasket to fit it.....NOTHING. Guy in the plumbing dept. said he had not seen a gasket like that sold seperate. It was only sold in a pack with about 10 other mixed gaskets that I figure I would never use. I just through in an o-ring and tightend it down. I like the pex valve idea!
giff is offline   Reply With Quote
Old 01-14-2012, 06:48 PM   #20
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
I retro fit my low point drains with shut off valves. half turn open, half turn closed. Don't need to worry about loosing plugs.
Jim,
this is EXACTLY what we want to do to our trailer! Mainly for the fresh water tank.
How difficult was this project? How long did it take you to do it? i think ALL trailer should come with this feature.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
