Old 07-25-2013, 08:53 PM   #11
This campground is on a hill side and the roads are terraced and the supply for this site is coming from a hose from the site below us. I'm sure were losing pressure from it trying to push uphill. May talk to someone in the AM. Thanks, to all for ideas.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 07-28-2013, 06:49 AM   #12
wanderer03's Avatar
Originally Posted by denandra2 View Post
Try removing the waterpur filter, I had very low pressure from external water supply on my Columbus 320, it is only a couple of months since I took delivery. I removed the filter and that solved my low pressure problem!
Happy Camping!!!
Hate to be a newbie and ask a silly question, but did you remove the filter completely ? I seem to have very very low water pressure , I had my motorhome in the exact same spot, then I parked my 5th wheel in the spot and now have Lowe water pressure , and thought about removing the filter and just leaving the canister only or is there a product that I can install and completely remove the entire water filter system?
wanderer03 is offline   Reply With Quote
Old 07-28-2013, 06:58 AM   #13
I think you can buy fittings and just connect the filter inlet pipe to the outlet pipe.
Old 07-28-2013, 02:21 PM   #14
If you just remove the filter canister, it should be the same as connecting the inlet to the outlet. And a lot cheaper and easier!
Old 07-28-2013, 05:52 PM   #15
semi-senior member
denandra2's Avatar
I just removed the filter and installed the canister without the filter, works for me. Looking for replacement filter for basic sediment and filtration. Until then just using external filter that I used previously used, it is a Camco canister type.
Happy Camping!!!!!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
