07-25-2013, 07:57 PM
Help with low water pressure
2013 340 RK Columbus. Tell me if this will work. If I have low pressure from the campground, can I connect campground supply to the winterize connection, swap the blue valve from normal to winterize, and use the pump as a booster pump. If it won't work, why not. Thanks in advance.
Paul
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
07-25-2013, 08:01 PM
Why not just fill the fresh water tank and use the internal pump?
2014 Flagstaff 27RLWS
2004 Chevy Avalanche 2500
1998 21' Thor (doesn't everyone need 2 TT's?)
07-25-2013, 08:05 PM
Were doing that now. It took at least 30 - 45 min to fill the tank. Looking for another altrnative.
"Paul & Laurie"
07-25-2013, 08:12 PM
I am not the expert here but if the pump flow exceeds the water volume coming out of the hose, you could damage the pump as you would keep running it dry and not gain any additional water pressure
When I have low pressure, I fill the fresh water tank, and reconnect the water supply to the RV site supply inlet, when I need additional pressure turn the pump on and it augments the campground supply. Basically use both and I do not use a full tank on a trip.
Also, have an Oxygenics shower head which helps.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
07-25-2013, 08:17 PM
Bill m That sounds like a reasonable option. will try in the AM. Thanks. I too am concerned about the pump not getting enough water.
"Paul & Laurie"
07-25-2013, 08:21 PM
Attach the shore water hose to the winterize connection and open the valve. With your FW tank to pump suction valve open (it normally is), you will backfill your FW tank in about 5 minutes. Be careful and make sure your vents are open. (Open the cap to the normal FW tank fill connection.) Otherwise you'll blow up your tank - not good. This is how I rinse out my tank after I've sanitized it.
To do what you want to do, you would do the same, except you'd close the pump suction valve to the FW tank so you don't fill the FW tank. I'm not sure exactly what might happen if you try this. Seems like as soon as the campground + pump pressure rose to the pump cutoff pressure, the pump would stop. So you wouldn't be any better off than pumping from the FW tank, except that you wouldn't have to refill the tank. On the other hand, putting 20-30 psig water to the suction of the pump, which isn't per design, might do bad things to the pump.
07-25-2013, 08:25 PM
Rockfordroo , I got ya. I don't need to mess up the pump.
"Paul & Laurie"
07-25-2013, 08:35 PM
You could use the fresh water tank as stated. Just don't let the tank run dry and it will not take as long to fill. You will have to refill the tank more often but not a long each time.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
07-25-2013, 08:37 PM
semi-senior member
Try removing the waterpur filter, I had very low pressure from external water supply on my Columbus 320, it is only a couple of months since I took delivery. I removed the filter and that solved my low pressure problem!
Happy Camping!!!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
07-25-2013, 08:53 PM
This campground is on a hill side and the roads are terraced and the supply for this site is coming from a hose from the site below us. I'm sure were losing pressure from it trying to push uphill. May talk to someone in the AM. Thanks, to all for ideas.
"Paul & Laurie"
07-28-2013, 06:49 AM
Happy Camping!!!
Hate to be a newbie and ask a silly question, but did you remove the filter completely ? I seem to have very very low water pressure , I had my motorhome in the exact same spot, then I parked my 5th wheel in the spot and now have Lowe water pressure , and thought about removing the filter and just leaving the canister only or is there a product that I can install and completely remove the entire water filter system?
07-28-2013, 06:58 AM
I think you can buy fittings and just connect the filter inlet pipe to the outlet pipe.
07-28-2013, 02:21 PM
If you just remove the filter canister, it should be the same as connecting the inlet to the outlet. And a lot cheaper and easier!
07-28-2013, 05:52 PM
semi-senior member
I just removed the filter and installed the canister without the filter, works for me. Looking for replacement filter for basic sediment and filtration. Until then just using external filter that I used previously used, it is a Camco canister type.
Happy Camping!!!!!
Dennis & RuthAnn
Tippy too!
Aisin 6speed Auto
SE Mo
