Old 10-18-2016, 06:49 PM   #1
Help with outside shower fittings
So I bought a Crusader 295 and it has the quick connect connection for an outside shower but did not come with the hose or disconnect. The connection is much like an air chuck connection on your air compressor. Does anyone know where I can find the associated parts?
ibboatin28 is offline   Reply With Quote
Old 10-18-2016, 07:14 PM   #2
SeaDog's Avatar
Welcome to the forum it a great place to get your questions answered. I have never seen what you are talking about could you supply a pic?
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-18-2016, 08:03 PM   #3
Outside shower
Of course. I should have thought of that. It's on the lower right side.
Old 10-18-2016, 08:45 PM   #4
SeaDog's Avatar
I hope someone on the forum can answer your question. it looks like the connection for the wand of a pressure washer to me. couple of options put a standard shower head back on or remove the fitting and take it to someone that deals with those fittings.
Retired Navy
Old 10-18-2016, 09:21 PM   #5
KenHwy61's Avatar
It is a quick connect fitting. Your camper probably was meant to have a hose that works with it. I had the same fitting and a matching hose. I found it was very hard to get the hose connected while under pressure and replaced the fitting with a standard garden hose fitting available most hardware stores.
Aviator Wright-Flyer#1908
1996 Holiday Rambler
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 10-18-2016, 09:35 PM   #6
Petersb's Avatar
You should be able to find those quick disconnect fittings at any parts store. Both ends and replacement hose at any rv dealer parts dept.
Petersb is offline   Reply With Quote
Old 10-18-2016, 10:08 PM   #7
I've looked all over and no go on the disconnect. I wanted one to make a 12" hose for black tank flush. Several I looked at appeared to be the proper fitting but none would fit. It's a very precise cut system. Possible that this one might fit but I don't want to go through the hassle of having to return it if it doesn't.
https://www.amazon.com/Phoenix-9-SA-.../dp/B003HK57T4
BUT, the OP indicated no hose came with the RV. Here is where one can get it:
Spray-Away / Coil Hose 15' - DW Inc.
BIRDS AREN’T REAL
Old 10-19-2016, 04:46 AM   #8
I think emm-Dee has found what I needed. It's evidently no a shower just an outside spigot.
Thanks everyone for the responses...
Old 10-19-2016, 04:47 AM   #9
grumpy0374's Avatar
The quick disconnect listed here is the one you need. The faucet you have pictured is made by Pheonix, and used their adapter. I know, because I replaced the silly outside faucet with it's unusable 5 foot hose with the Pheonix unit you have. Their disconnect works perfectly, and I have it on a 25 foot hose so my wife can wash our 2 dogs on the road. Allows the hose to be brought around to use under the awning. It's pricey, but no other adapter from the aftermarket seems to work right. A worthwile mod.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 10-19-2016, 06:45 AM   #10
Grumpy
Thank you very much, Steve. I was hesitant to order that part because I had previously bought three different versions of the fitting and had to return them. They all looked like they would fit but the Phoenix fitting is so well built I guess a micro amount of difference won't allow other fittings to work.
BIRDS AREN’T REAL
Old 10-19-2016, 10:15 AM   #11
MNtraveler's Avatar
In that Amazon listing, if you look at the "frequently bought together" listing, you will see a quick connect hose that works with this type outlet.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 32; RV to date: 35
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 10-19-2016, 10:16 AM   #12
MNtraveler's Avatar
Name:	ImageUploadedByForest River Forums1476890199.535502.jpg
Old 10-19-2016, 10:21 AM   #13
Thanks to all for the good info.
We're taking off to try the camper out tomorrow but will certainty order one when I get back.
Old 10-19-2016, 11:29 AM   #14
Thanks. Unless that's a 25' hose it's cheaper from the distributor.
BIRDS AREN’T REAL
Old 10-19-2016, 12:59 PM   #15
MNtraveler's Avatar
Also if you just buy the fitting, you can use any standard garden hose of any length needed.
However if what you want is to use a standard hose or any long hose, you might want to just put one of these on the water source tap:
Camco 20113 Wye Garden Hose Valve - Metal https://www.amazon.com/dp/B000BUU5SQ..._Wm7bybXW6D1D3
Also available at Sears or any hardware store.
One big benefit of the connection to the RV is being able to use it with the water pump when not connected to city water. Sometimes, for example, even when you have city water at a CG you get to the dump station and there's no water or no suitable hose connection for black water flush. The RV connection to your own hose at least gives you some water to flush out with, if not much power to it. Likewise most RV water pumps will not power a large size garden very well.
Old 10-19-2016, 01:45 PM   #16
ben31's Avatar
Did you buy the Crusader new? If so, the dealer should provide you with a hose. It was supposed to come with one.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 10-19-2016, 03:07 PM   #17
you can get the hose at most RV dealers. look for a blue plastic coil like hose and it has thecorrect male side to your quick connect. It is a common item.
hillsdaletc is offline   Reply With Quote
Old 10-19-2016, 05:46 PM   #18
Nope bought it used.
Camping world doesn't supply squat. Not even a sewer hose.
Good selection but hard to deal with.....
show, shower
