Old 06-12-2010, 09:05 AM   #1
help with sanitizing/draining freshwater tank
I have a Grand Surveyor 04 GS290 - New to camping. How sanitize and drain the freshwater tank on my trailer?
kinnaird is offline   Reply With Quote
Old 06-12-2010, 09:47 AM   #2
grhodes50's Avatar
Your fresh water tank should be located close to the Fresh Water Connection (should be a label on the outside of your trailer). Look under the trailer and locate a small peacock valve (usually white in color). Open this valve to drain your fresh water tank.
Check out the following thread. They have instructions on sanitizing your system.
http://www.forestriverforums.com/for...-not-6346.html
Hope this helps.
Gary & Trish
2018 Nights Camped - 5
Old 06-12-2010, 11:05 AM   #3
Thank you for responding. I located it. This really helped.
