Old 04-13-2019, 06:55 PM   #1
Help! with steady water leak
I have a 2018 Vengeance 26FB13 toy hauler that Iím trying to de-winterize. When I put water to it there is a blue PEX pipe protruding through the underside insulation mat up front just inside the hitch frame that runs a steady stream of water. I canít for the life of me find a valve anywhere to shut that off. Can anyone offer some advice? Iíve searched the manual and it says nothing about that drain line that I can find.
Thanks!
Ezgoin721 is offline   Reply With Quote
Old 04-13-2019, 07:01 PM   #2
007matman's Avatar
Sounds like your low point drain.
Does it have a threaded nipple? Typically, there should be a cap on that.
007matman is online now   Reply With Quote
Old 04-13-2019, 07:01 PM   #3
cavie's Avatar
Thanks!
Sounds like a low point drain. Do you have a compartment with a bunch of valves in it?
Where are you putting water?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-13-2019, 07:31 PM   #4
bikendan's Avatar
Pics are often more helpful than written descriptions.
Equalizer WDH
Old 04-13-2019, 08:04 PM   #5
Yes it is threaded. It's odd, because it's located way forward of any part of the water system, like under the bed in the front of the trailer. I wondered about jut putting a PVC cap on it. I have a pic, but not sure how to get it to load.
Old 04-13-2019, 08:40 PM   #6
It does sound like a low point drain, cap it and your problem should be solved.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 04-13-2019, 08:43 PM   #7
007matman's Avatar
Are you using a smartphone?
Apps all work differently. I like Tapatalk. It's easy to use.
The Cap is probably what you want to do. Is there any other drains?
My camper has a red and a blue line with caps.
Old 04-14-2019, 08:20 AM   #8
I put a cap on it and everything seem to work good now. The fresh water tank filled and everything seems to hold pressure when on city water. I do have two other drain hoses under the water tank area under the trailer, a red and a blue with plastic ball valves, but this other drain line is way up front on the trailer. Seems like an unusual place to run a drain. I think Iíll pull the cap I installed and put on a ball valve for ease of draining and securing.
We bought this trailer back in October from a couple who purchased it new and only used it once before their situation changed and they had to sell it. It was a great deal for us except we didnít get the walk through of how everything works and where everything is at, and the manuals for the camper itself are vague at best! Itís our first travel trailer so itís a learning process for us!
Thanks for all the quick input and help!!
Old 04-14-2019, 02:59 PM   #9
Under the bed
Thanks!
Take a look under the bed. Is the fresh water tank there? If so, the fresh water tank has filled up and water is coming from the overflow.
There's a check valve (one-way valve) that prevents the fresh water tank from filling when you are connected to city/well water. If that valve sticks, the fresh water tank fills and overflows.
The customary way to clear the check valve is:
1) Turn off/disconnect city water
2) Open a tap to relieve pressure
3) Turn on RV's water pump
4) Turn a tap on and off a few times to flow water through the check valve in the proper direction and flush it.
5) Turn off pump.
6) Turn on/reconnect city water
If you are headed to a place that has water, you may wish to drain the fresh water tank. No need to haul a couple of hundred pounds of water.
Larry
Larry-NC is offline   Reply With Quote
Old 04-14-2019, 05:57 PM   #10
I’d be looking more along the lines of what Larry is talking about. If you have two other lines, red and blue, those are your low point drains. Did you do the winterization? If so did you remove the end cap? Sounds more like an over flow line, I’d be concerned with plugging it.
lewisra is offline   Reply With Quote
