Old 02-17-2015, 05:55 PM   #1
Maron
Send a message via Yahoo to Maron
Help with the outside shower
Our 2014 Rockwood 8329 is just dribbling when we turn on the outside shower.
1. Does the on board water system pump into the outside shower to can we use city water?
2. Even though we de winterized the TT, only dribbles come out when we have the on board pump turned on to the outside shower.
Any and all answers will be welcome!
Maron is offline   Reply With Quote
Old 02-17-2015, 06:01 PM   #2
the outside showers are never very good from what ive seen. Might take the shower head off and try it to see if something is kinked or clogged. It should run on city or pump like anything else... good luck
firedaniel is offline   Reply With Quote
Old 02-17-2015, 06:07 PM   #3
Flybob's Avatar
In addition to the faucets, there is a shut off in the shower head. Make sure it is open.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-17-2015, 06:23 PM   #4
geotex1's Avatar
X2. We actually had the rotary on/off on the head fail too, and our friend's new camper came with BOTH supply lines to the outside shower kinked nearly closed.
geotex1 is offline   Reply With Quote
Old 02-18-2015, 12:15 PM   #5
RudysWorld's Avatar
After I de winterize I usually get sediment from water heater clogged in faucets I would unscrew and see if clogged with sediment.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 02-18-2015, 12:35 PM   #6
Unscrew the shower handle from the hose and see if water is running. I bet it is the shut off valve at the base of the handle, which by the way, does not completely shut off - it allows a dribble of water.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 02-18-2015, 12:54 PM   #7
Boso's Avatar
Outside shower
Make sure bypass valve is open and not in the bypass position
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 02-18-2015, 07:44 PM   #8
There is a neat attachment to flush out your hot water tank. Attach it to a garden hose, stick it in the drain plug hole and twist it around. You'll be surprises at the crud that comes out. Check your exterior shower head, it may have a restrictor to reduce the water flow. It's just a washer with a very small hole in it, take it out, throw it away and put another washer in it's place with a bigger hole. This problem can also restrict flow to the inside bath shower head also.
tomrob1161 is offline   Reply With Quote
show, shower
