Old 09-01-2015, 06:43 AM   #1
fordsuperdutyE350's Avatar
High water pressure when water heater is first turned on?
I have been getting a burst of water pressure when I have turned the water heater on for hot water when ready to shower. This is on gas. It also does it on electric. When I go to the faucet and turn it on there is a burst of high pressure. Could the water heater pressure Valve be bad? Not to long ago I blew the bottom out of my water filter housing. Luckily I was in the camper when it happened...if it is the pressure valve how hard is that to change? I have a 2013 Forest River Flagstaff suburban water heater.
fordsuperdutyE350 is offline   Reply With Quote
Old 09-01-2015, 07:00 AM   #2
Forbes's Avatar
Most RV or home supply stores sale pressure reducer that attach to your supply hose also the burst of high pressure from hot water is due to the fact hot water expands therefore increasing pressure.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Forbes is offline   Reply With Quote
Old 09-01-2015, 07:15 AM   #3
SYE
SYE's Avatar
My water lines were tested at 90PSI, so I have not stayed at any park that has that high of pressure requiring a regulator. The hot water in your tank will expand and produce a but of pressure when you first turn it on. once it is relieved it should be good. As for your water canister getting blown off, if it is the FR1 with the KW1 filter there a a few known issues with these such as putting in the wrong filter or no filter at all then you tighten it too much when you do this and it breaks off the locking tabs that keep it on there.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 09-01-2015, 07:32 AM   #4
Water line pressure
No none of those I have no issues there. I have a presure regulator and the canister was ok. I am getting a burst of presure, not continual presure and only happens when water is being heated. I do not think the how water presure relief valve on heater is working properly. The hot water heater will leak a small amount on outside of camper at times
Old 09-01-2015, 08:00 AM   #5
SYE
SYE's Avatar
If you think it is bAd, replace it.
Scott & Vicki
Old 09-01-2015, 08:04 AM   #6
If the Temp/Pressure valve is leaking a little when the water is heated I would look more towards the temperature control first. Have you checked the water temperature after the heater is done cycling?
Filthy Beast is offline   Reply With Quote
Old 09-01-2015, 08:22 AM   #7
Bill_C's Avatar
Once the water is past the pressure relief valve into the trailer it is locked there. The water is cold. You turn your hot water heater on. As the water heats it expands increasing the line pressure. It will not go backwards out of the trailer to relieve excess pressure. You do have a safety relief valve on your hot water heater that is supposed to release high excessive pressure during the heating process. Try operating it manually a few times and make sure it is not plugged or seized. You may have to replace it.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-01-2015, 08:35 AM   #8
VinceU's Avatar
Have you tried to restablish the air cushion in the water heater? Block water service to the RV, carefully bleed off water level using the heater tank relief valve until it stops flowing. Release valve handle. Now you'll have an air space for heated water to occupy without driving up pressure.
Old 09-01-2015, 08:41 AM   #9
BooBoo23's Avatar
X2 If you are water heater is leaking at times that would indicate the pressure relief valve is working. You may have a faulty temp sensor and may be letting the water get too hot.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 09-01-2015, 08:56 AM   #10
PhoneDude 8289's Avatar
X2 for VincwU, you need an air cushion
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
heater, pressure, water, water heater
