Old 07-31-2011, 02:19 PM   #1
fast murray's Avatar
holding tank q's
We have a wildcat 5th wheel that I either can't get the holding tanks empty, or the gauge on the wall is wrong. It has a tank for the kitchen, one for the bathroom, and one for the toilet. They all read 1/3 full, but the black one is borderline on 2/3 full. Any thoughts?
fast murray is offline   Reply With Quote
Old 07-31-2011, 02:33 PM   #2
Oakman's Avatar
The tank gauges are notorious for not working correctly and giving false readings. I rarely pay any attention to them anymore.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-31-2011, 02:34 PM   #3
J. Parham
snjparham's Avatar
Well, you could have crud on the sensors causing them to read this way. One way to be sure would be to use a clear elbow next time you dump. Let your tanks drain until nothing flows through the elbow. If you still read one third you probably have crudded sensors. Others suggest ice in the tanks to clean the sensors.
2011 8528BHSS
2013 Silverado 2500HD 6.6L
Nights Camped in 2011: 32
Nights Camped in 2012: 85
snjparham is offline   Reply With Quote
Old 07-31-2011, 02:51 PM   #4
Man I wish we had a seperate tank for the kitchen....
Can you see the tanks underneath? Ours are clear and exposed so I can see the levels..
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 07-31-2011, 03:02 PM   #5
sherdep's Avatar
silly question but has it ever read empty at some point?
Reason I asked is if you knew that the senors were hooked up right from the start and not giving false readings.
I had an issue where one of mine was giving a false reading and I filled the tanks up and let them sit for a few to try and soften any junk on the sensor probe.
I also have a Tornado installed in my tank and use a clear elbow to make sure all the junk is out of the tank.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-31-2011, 08:33 PM   #6
We've only had the camper for about a month and it's an 04. The tanks are not exposed on the bottom, most of the trailer has a covering on the bottom. Where would the clear elbow be installed? When I dumped it out I went until nothing was coming out anymore and when I got home I opened them in the yard. Nothing is coming out now. What kind of sensors are these in the tank? Lastly, the black tank is the weirdest one, could it have a layer of crap in the bottom that has hardened? If I fill that tank with water, would it come up in the toilet when it's actually full? Thanks for the replies.
Old 07-31-2011, 09:19 PM   #7
Lottery Non-Winner
Ovair's Avatar
Yes there could be some dried stuff that is causing the readings to be off. For the black tank it may be obvious what that would be, but for the gray tank you can still have "gunk" mucking up the sensors. Long soaks might help, but might not. These things are usually not accurate anyway.
The clear elbow would be installed at the camper end of the sewer hose. When you pull the valve open, you can visually observe whether the liquid is running clear or not.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 07-31-2011, 09:23 PM   #8
CampeRooo
rthrbelsewhere's Avatar
The following links are for reference only:
The 90* clear elbow that was mentioned looks like this - Save at RV Partscenter - RV Parts and Supply attach it to the hose and then twist it onto the dump outlet on the rig and that way you can see what's going on when you open up the tank valves.
Stock probes probably look this this (don't know for sure, i've never pulled one off) - - 226 Holding Tank Sensor Probe - Price: $2.00 - Factory RV Surplus - 1611 W Bristol St, Elkhart, IN 46514 (800) 325-1461 (574) 262-3327 upgraded probes look like this - RV Holding Tank Sensors - Get accurate grey and black holding tank monitor readings
If you filled the black tank with water, you would be able to see it come up through the toilet flap. When I end a long trip with our TT, I'll hold the black tank until either we leave or it winds up full. If it's not full when I go to dump it, I'll run water into the bowl and flush it until it is full. Then I'll dump it. Refill the black tank again with just water and then dump it again. Then I'll dump the gray tank and it's good to go. I know that this is a bit of a waste of water, but I don't have a rinse mechanism like some people do. Eventually I will, but until then, this is what I do.
Everyone will have a different way of doing things when it comes to keeping that black tank cleaned out and deodorized. My arsenal consists of using an enzyme additive called "Unique RV digest-it", calgon powdered water softener (now that I found some), and a toilet cleaner/deodorizer packet when I need to clean the bowl up. Outside of that, I guess I've been fairly lucky to not have had any problems at this point.
If you believe that your tank might have a layer of stuff stuck it, then I believe that most people on here would recommend something along the lines of filling about 1/2 of the black tank with water and add your chemical of choice and leave it all in there for a few days or so (Unique might work for this, I don't know). Then, on the day you go to dump it out, pour in a bag of ice into the toilet and flush it through and then pull the trailer around for a bit to let the ice rattle things loose to knock off anything stuck on the sensors or the bottom of the tank. Then go dump. Hopefully that will help with most of that. Good Luck!
{added} Oh I guess I should also mention that you should avoid using things like vinegar, Clorox, or anything that would "sanitize" your black tank. Enzymes and other bacteria need to survive in order for your tank to stay in good working order. If it's "too clean", then the solids won't break down as easily or at all.
Joe
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 07-31-2011, 09:35 PM   #9
Herk7769's Avatar
http://www.forestriverforums.com/for...1-a-12710.html
This thread is how I fixed my false indications.
I have dry camped with them 7 months now and the tanks have dumped to empty every time.
I am VERY happy with my Horst Probes.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
