Old 01-28-2016, 11:20 AM   #1
TsnTexas's Avatar
Holding Tanks in cold climes
As we are new to travel trailer camping I'm wondering if the holding tanks will crack when the liquid freezes inside them. We often camp in "off the grid" nat'l forest campgrounds where the nighttime temps get down into the low 20's. I don't think it's practical to run heat strips off the battery. I suppose you could add an antifreeze product to the black and grey water, but obviously not in the fresh water tank. Question is - what are the guidelines for camping in freezing conditions? (by the way we're in the process of buying a Rockwood 2504s)
Thanks for your input in advance!
TsnTexas is offline   Reply With Quote
Old 01-28-2016, 07:19 PM   #2
VizJedi's Avatar
I know the manuals all say to drain the black, grey and fresh water tanks when winterizing. In the 14 years I have owned trailers, I have probably had some liquid in the holding tanks more than I haven't. And never had a problem.
As long as the tank isn't completely full, the fluid freezing will have room to expand and not cause any problems. There could potentially be problems with drain pipes and valves, but I never had any issues with 4 different trailers.
Now, water lines are another story. Small, contained tube with no room for expansion = broken water line.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
VizJedi is offline   Reply With Quote
Old 01-28-2016, 09:38 PM   #3
If you have some water in the bottom of the tanks there should not be a problem, if you have water trapped between the drain valve and the cap, well that could be a problem.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
tank
