Old 12-23-2012, 11:29 PM   #1
Holding Tanks release pull handles
Any suggestions on best way to lubricate. Mine very hard to open/close. Tks!!!!
Cardinal camper is offline   Reply With Quote
Old 12-24-2012, 06:08 AM   #2
I dropped the belly enough to get to the valves and lubed them but it did not help. The problem on my unit is the cables have to curve to get to the valves.
jdecanter is offline   Reply With Quote
Old 12-24-2012, 06:35 AM   #3
On my Silverback, they were hard right from the time we bought it new. This past summer the black water tank valve stopped working completely. We were 2000 miles away from home and the RV place out west told us it was the valve that needed replacing. It would take two weeks to get one in. We would be on our way home by then. I used an end of the line valve and the RV place was able to open the black water valve. Anyway when we got home I took it to the place where we bought it and they said it was the cable that was bad. They also replaced the cable to the grey water valve. While out west I unhooked the cable from the L bracket and was able to pull maybe 6 feet of cable. Why it was/is that long is beyond my reasoning. Shorter ones were installed tho'. My dealer mechanic said it was the outer sheath on the cable that caused the problem.
Pipeman is offline   Reply With Quote
Old 12-24-2012, 08:02 AM   #4
Oklahoma Proud
MillerTime's Avatar
I have purchased some seal lube that you pour down into each tank to help the valves from sticking. If you have cables, there is a cable lube kit for motorcycle and quad cables that forces lube down the sheath. I will try to get pics of both in a little bit.
Old 12-24-2012, 08:09 AM   #5
I exchanged the standard cables with cables made for bicycles. The cables are teflon coated and run VERY smooth.
Flying dutchman is offline   Reply With Quote
Old 12-24-2012, 08:25 AM   #6
Tks!!!!
Old 12-24-2012, 03:02 PM   #7
If you could show pictures or a "link" to these cables for bicyle cables it would be great . Jim
FarmerJim is offline   Reply With Quote
Old 12-24-2012, 03:16 PM   #8
http://www.blueskycycling.com/cat-cable.htm
I bought mine from my a bicycle dealer in NJ.
Merry Christmas
Old 12-24-2012, 03:27 PM   #9
Farmer Jim. You may search ebay for "brake cable for bicycle".
Many choices.
Old 12-24-2012, 11:22 PM   #10
Oklahoma Proud
MillerTime's Avatar
Here is the chemical and also cable luber I mentioned earlier
