Old 09-08-2012, 01:02 AM   #1
Holding tanks sizes
We purchased our 2013 Wildcat 26BHS 12 weeks ago. Realizing i was having to empty the gray tank more frequent than i should , I tested the capacity of all tanks. The tanks hold 30 gal. each. All the info that i can find say that this model should have:
FW=50 gal
GW=80 gal
BW=40 Gal
The weight label indicates that FW is 358 lbs. which is appro. 43 Gal, still not to spec.
Anybody have an idea what the deal is and can i expect it to be fixed?Thanks
mikem84 is offline   Reply With Quote
Old 09-08-2012, 01:21 AM   #2
Phat Phrog Stunt Crew
awwall's Avatar
Since you have tested the capacities and feel good about it, I would be making a trip back to the dealer. Some goof off during construction could have stuck 30gal tanks on all 3.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 09-08-2012, 01:26 AM   #3
wyo700's Avatar
My camper only shows that I am supposed to have a 56 gallon tank but I have the additional 50 gallon tank. So I have 106 gallons total. It was a good mistake for my benefit. My gauge would always be right between 1/3 and empty when returning home and then I would empty my fresh water tank and it would drain forever. Then I looked under and noticed I had two fresh water tanks.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
