Old 03-25-2019, 09:40 PM   #1
DaleV's Avatar
Hole thru outside wall in bathroom
We have owned our camper since July of last year and I just noticed a hole under the bathroom sink thru the outside wall. I saw the access from the outside but didn't know where it was inside until just now. I'm actually glad I found this... I'll be able to use it for my WIFI antenna wire!
I'm just curious if anybody knows what this might really be used for.
ID:	199829   Click image for larger version
ID:	199830   Click image for larger version
ID:	199831   Click image for larger version
DaleV is offline   Reply With Quote
Old 03-25-2019, 09:52 PM   #2
That is where the shore power cord entered the R/V. Seems someone removed the permanently wired cord. Did someone install a removable 120v connection nearby?
The slot in the lid allowed the lid to be closed on the cord when pulled out and the cord was pushed into the port and stored inside the R/V when unplugged. The plug would reside just inside the lid when unplugged and stored and the lid snapped shut with the tab.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 03-25-2019, 10:59 PM   #3
DaleV's Avatar
Oh! That makes sense. I didn't think about electric. The picture with that port closed shows the city water connection, fresh water tank inlet, and electric below it. The port that our 30 amp cord is stored in does look similar.
I wouldn't have guess electric at all. Where the 30 amp cord is stored is closer to the fuse panel.
Old 03-26-2019, 07:54 AM   #4
Maybe someone added it for something else.
If you already have the same kind of hatch for your shore power cord then I have no clue other than someone maybe wanted to run an electric heater off the 20a outlet in the pedestal and they added the hatch to run an extension cord through there??
Old 03-26-2019, 08:07 AM   #5
dbledan's Avatar
For my trailer that is the propane quick connect port.
dbledan is offline   Reply With Quote
Old 03-26-2019, 09:28 AM   #6
DaleV's Avatar
Yeah that's a possibility.
Thanks for your opinions, 5picker!
Old 03-26-2019, 09:31 AM   #7
DaleV's Avatar
I don't know how that can be used for propane. Can you give me an example?
Old 03-26-2019, 09:41 AM   #8
Chuck_S's Avatar
It's for the power cord. Cord is permanently mounted to the trailer -- was -- and the hole is to just stuff the cord back in the storage cabinet without having to remove it. Used to be a standard type of connection, we had it on our popup several years ago. Until I did the same thing and made the cord detachable and gained a nice interior cabinet that was previously full of often damn, dirty power cord.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 03-26-2019, 09:41 AM   #9
dbledan's Avatar
Yup. I have a hose inside the vanity cabinet that leads to the port on the outside like this so I can attach my grill.Click image for larger version
Old 03-26-2019, 09:44 AM   #10
I have the same quick connect set like that on our old ! 1987 Jayco popup. The hose came out of that port and you can take the stove outside and hook it up.
TheWolfPaq82 is online now   Reply With Quote
bathroom, roo
