05-19-2011, 02:00 AM
Horrid water pressure in Kitchen
I have a 2011 TT (30WRLTS) and my kitchen sink pressure is horrid! Bathroom pressure is good. I have heard about water restrictors, but cant seem to find it/them if indeed they are there. Any suggestions? I have checked the screens to see if they were clogged, there were actually about 7 of them in there, so I removed all but one and this didn't help. The restriction seems to be between the end of the hose (with spray head removed) and somewhere beyond. Please HELP!
Much Thanks in advance!
05-19-2011, 06:52 AM
I thought maybe you had a kinked supply line but if both the hot and cold water are restricted that theory is all wet. (pun intended)
Same applies to a blocked water filter because it only filters the cold water.
Is the water restricted when you're connected to city pressure or just when running off the 12v pump?
You could try removing the water lines from the faucet to see how much flow you have when the faucet is bypassed. The issue may be in the faucet itself.
Since it's a 2011 it's probably still under warranty so you have the option of taking to the dealer for an inspection.
Good luck.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
05-19-2011, 06:53 AM
Once you have eliminated the spray head as the problem. It is a dealer issue. Sawdust and construction junk can get into the PEX tubing and clog the valve body of the kitchen faucet. Replacement is your only option if this is the case.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-19-2011, 07:42 AM
Is your kitchen sink on a slide? maybe it is kinking when slide goes out?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
05-19-2011, 08:18 AM
Excellent input!
05-19-2011, 10:20 AM
It's not on a slide and I am connected to city water. When the pump is engaged the pressure is fine! Truly perplexing!
05-19-2011, 10:58 AM
Crappy regulator maybe?
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
05-19-2011, 12:07 PM
Ditto on the "Truly Perplexing". The pump output and city water input should come together at a "T" fitting, then route to the kitchen. Pressure, good or bad, should be the same.
05-20-2011, 08:06 AM
Excellent thought. What is the pressure like at the hose? Try removing the regulator and see if the screen is clogged or the check valve in the city water port is stuck.
05-20-2011, 01:22 PM
Nope Nope and Nope, calling a service guy next week.
05-24-2011, 10:24 AM
My old trailer had a screen on the faucet which would plug up after sitting all winter. Generally after a half hour of screwing around trying to get water, I would remember to take the screen out and clean it.
05-24-2011, 12:27 PM
is ur sprayhead also ur water outlet for the sink (is the spray head selectable...spray or steady stream)? am i reading correctly that the pressure is ok with the head removed?
i have a kitchen faucet in my home like that. when i disassembled the head, the water ports are very small.
if this is the case, a different brand faucet could solve the problem.
06-21-2011, 10:26 AM
We are having the exact same problem in our 2011 Berkshire 36FWS. Water pressure hot & cold in the bath sink is great, but the kitchen sink hot & cold is not really useable when connected to city water. We have replaced the pressure regulator we use when on city water. Our kitchen sink is on a slide and the bath is not. I have checked all the shutoff valves and checked all I can think of. Unless someone has an idea I guess we will have to deal with it till we get back home to the dealer.
06-21-2011, 12:09 PM
Look for:
A pinched flex water hose (under slide)
Crud in the aerator screen.
Crud in valves or fittings.
06-21-2011, 03:46 PM
We have checked everything you mentioned except I have not taken the single handle faucet apart in the kitchen to check it. I'm beginning to think it has to do with the actual faucet and perhaps because it's a single handle and not dual handle like the bathroom.
06-21-2011, 04:09 PM
it's probably going to be back to the dealer.
the only thing left is to back wash from the faucet back. i say turn the water off and open the faucet at the lavatory or shower and see if u can force water back (apply water via external hose at kitchen faucet. allow to drain out at shower).
if it is compressed debris, reversing flow is likely to dislodge it).
06-21-2011, 07:26 PM
It's new - so do it under warranty, but if it weren't I'd start at the spigot and work out from there. Including the connection hose. Is it possible that a rubber washer got blown down the hose? What is weird is that the bath pressure is fine and the kitchen is not, but still start at the source.
***** ***** ***** 2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
06-28-2011, 04:34 AM
I had horrible water pressure at my kitchen faucet also. I replaced the kitchen faucet due to a broken handle and the new faucet had unbelivable water pressure! Just like in my house!
Dwayne
06-28-2011, 06:24 AM
There is a one-way check valve or when you are on city water, designed to keep from back-feeding your pump and fresh water tank. Sounds like it may be installed backwards, and that the the little bit of water that you are getting is what you are squeezing past it...
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
