Old 02-02-2013, 07:32 PM   #1
lonestar007's Avatar
Thumbs up Horst miracle probes
FYI >> Found why I have false reading on my Black & Grey tanks!
HORST MIRACLE PROBES
Horst Miracle Probes for Wastewater Tanks in Recreational Vehicles RVs
Ordering them now! Amazon cheaper ($52) than from OEM $62
Probes, Gray Water, 4/pk : Amazon.com : Automotive
Probes, Black Water, 4/pk : Amazon.com : Automotive
lonestar007 is offline   Reply With Quote
Old 02-02-2013, 07:36 PM   #2
Herk7769's Avatar
Here is how I put them in:
http://www.forestriverforums.com/for...ion-16089.html
More info on the probes and system
http://www.forestriverforums.com/for...tor-26746.html
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-02-2013, 07:45 PM   #3
How about this way of removal?
Old 02-02-2013, 11:59 PM   #4
Herk7769's Avatar
I watched how he did it and it looks pretty good.
My only critique is that he is pulling the sensor through while the seal is still "squashed." This most likely will shear off the hard rubber of the seal as the sensor head is pulled through the hole. (and may damage the tank hole).
By leaving the nut on, and tapping the sensor towards the tank the sensor head is no longer squashing the seal and IT can be pulled through (with needle nose pliers or dykes) without the sensor head competing for space in the hole and then once the seal is clear the sensor head will come right out with no fuss.
His way seems more "forceful" but it worked for him.
Old 02-03-2013, 12:07 AM   #5
There some people are drilling 3/8 hole next to sensor without taking it out.
In my case - I would have hard time to work on the very top sensor due to abstraction and limited space.
BTW - does anyone having trouble with Fresh Water Tank sensors?
Old 02-03-2013, 07:22 AM   #6
Herk7769's Avatar
I did not change my fresh water tank probes. The issue in the holding tanks is conductive slime on the tank walls. A good cleaning with a sanitizer will clean the fresh water tank buttons.
Old 02-03-2013, 08:50 AM   #7
Herk You were having an issue with your gray tank probes in one of the threads you posted I was wondering if it was resolved??
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 02-03-2013, 02:13 PM   #8
I think you should also consider capacitive tank-level sensing. See this: https://tankedge.com/ or this: http://www.rvgauge.com/.
NUWA is/was using the second of these and I was very impressed. The first is available from Camping World.
Old 02-03-2013, 02:53 PM   #9
Herk7769's Avatar
Yes, grease glob on sensor.
Installed flush unit in gray tank.
All good now.
Old 02-03-2013, 05:22 PM   #10
Thanks,
I should do this as well!
Old 02-04-2013, 09:11 PM   #11
All good now.
Awesome so you would recommend these probes? I'm tired of the false readings in the black and grey tanks and will do this swap in the spring.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 02-04-2013, 09:24 PM   #12
Herk7769's Avatar
I do. Once you get the belly panel down (just do not pick a windy day) the rest is easy.
Old 03-02-2013, 02:23 PM   #13
Just installed new set of sensors - works as a charm! Shows all clear!
Old 03-02-2013, 02:51 PM   #14
Herk7769's Avatar
Remember that these sensors do not eliminate regular tank treatment (Calgon-Detergent); just makes them harder to foul.
Old 03-02-2013, 03:01 PM   #15
Thanks Herk this is on my springtime to do list before the season starts. I always put some Calgon in there.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 03-02-2013, 03:02 PM   #16
Dammit! I was sure they complitely eliminate all waist!
Old 03-02-2013, 03:28 PM   #17
Not-so-Junior Member
VenturaBill's Avatar
Originally Posted by BarryD0706 View Post
I think you should also consider capacitive tank-level sensing. See this: https://tankedge.com/ or this: SeeLeveL RV Gauges by Garnet Technologies Inc..
I watched the video on the Tankedge sensors and I'm impressed, I never knew they existed... It would only make sense to have the tank sensors outside the tank so they never get fouled. Plus the sensor reads in percentages, not in 1/3 or 2/3 increments which leave you guessing.
I also like the panel readout, plus the ability to set tank level alarms, ie: 85% for holding tanks and maybe 20% for fresh water, etc.
These are going on my upgrade list...
How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?
• 2012 F250 6.7L Lariat 4x4 long bed
• 2013 Columbus 295RL
• 1952 Blonde Nurse
VenturaBill is offline   Reply With Quote
Old 03-02-2013, 03:49 PM   #18
Herk7769's Avatar
I would love to know how it works out for you. My concern about the capacitance indicators was adhesion. I would hate to have one peel off while in the boondocks and have no idea about how my tanks were doing and no way to fix it.
Old 03-02-2013, 03:53 PM   #19
TURBS's Avatar
My boss has these on his mh .
They scuffed the tank lightly and used a thin flexible epoxy.
No issues that I know of.
Been on there for 5 years.
Just some info
Not the same brand either but similar.
Old 03-02-2013, 06:59 PM   #20
Herk7769's Avatar
Thanks Turbs,
I feel better knowing they stick.
